I started this Revell A-6E at the start of the year and it has been sat on the shelf waiting to be finished. I am going to mount it on a board when finished as it is a tail sitter. This is due to the numpty building it forgetting to weight the nose (I did have the stuff ready to one side).
The build up to now has not been without issues but nothing that couldn't be sorted with a bit of filler or pva. The wing roots and intake joins were the worst. A piece of the belly also needed attention again fit issues. The cockpit is not the kit one and again there was the usual issue with the fit of the thing. this did not become appparent until it was all stuck in place and I tried to fit the front cockpit glass. The instrument panel shroud sits a bit high and makes it difficult to put the glass in place. (And yes I did dry fit it all but I guess something moved).
[ATTACH]70893.IPB[/ATTACH]
[ATTACH]70894.IPB[/ATTACH]
[ATTACH]70895.IPB[/ATTACH]
[ATTACH]70896.IPB[/ATTACH]
[ATTACH]70897.IPB[/ATTACH]
[ATTACH]70898.IPB[/ATTACH]
[ATTACH]70899.IPB[/ATTACH]
