Nice work Terry, loving those fire extinguishers.
MH-60G Pave Hawk
The storage boxes and fire extinguishers are now finished and mounted in the cabin. I still have a couple of bits to add before I shut the fuselage up and move on to the rest of the build.
[ATTACH]78227.IPB[/ATTACH]
[ATTACH]78228.IPB[/ATTACH]
[ATTACH]78229.IPB[/ATTACH]
[ATTACH]78230.IPB[/ATTACH]
[ATTACH]78231.IPB[/ATTACH]
[ATTACH]78232.IPB[/ATTACH]
When I get home tomorrow pictures will be added to this post. The fuselage halves have been fused together but I hadn't noticed the nose joins had slipped leaving a step that will now need to be sanded out. I thought taping them would hold them true but it failed and the slip wasn't visible until the tape was removed.
I have also opened up a couple of parts on the intakes that were moulded as solid parts.Comment
Here are the pics I didn't have time to sort and post yesterday. The Front glass is only dry fitted at the moment.
[ATTACH]79804.IPB[/ATTACH]
[ATTACH]79805.IPB[/ATTACH]
[ATTACH]79806.IPB[/ATTACH]
[ATTACH]79807.IPB[/ATTACH]
[ATTACH]79808.IPB[/ATTACH]
[ATTACH]79809.IPB[/ATTACH]
[ATTACH]79810.IPB[/ATTACH]
[ATTACH]79811.IPB[/ATTACH]
[ATTACH]79812.IPB[/ATTACH]
The other intake has now been sorted and fitted as has the rest of the glass. There are a few gaps that will need attention but nothing to heavy. The front glass was a bit bad on fit but with a little sanding it eventually went into place.
[ATTACH]80204.IPB[/ATTACH]
[ATTACH]80205.IPB[/ATTACH]
[ATTACH]80206.IPB[/ATTACH]
[ATTACH]80207.IPB[/ATTACH]
[ATTACH]80208.IPB[/ATTACH]
[ATTACH]80209.IPB[/ATTACH]
[ATTACH]80210.IPB[/ATTACH]
Thanks Francesco. Today I am going to open the exhausts up as I have with the intakes. This is going to be a fiddly job as there are some really small openings. I am also going to rub down the small amopunts of filler I have used.Comment
