F-11E build
    F-11E build
    After a few relaxing days away seeing our new addition to the family I have or am about to start the F-111E.
    There are five sprues and one clear. There is no option to have the cockpit open so will dry fit the two cockpit halves with the tub and see how much work will not need doing.
    Also very few decals to apply
    [ATTACH]71934.IPB[/ATTACH]
    [ATTACH]71935.IPB[/ATTACH]
    [ATTACH]71936.IPB[/ATTACH]
    [ATTACH]71937.IPB[/ATTACH]
    Interesting!
    It's true, there aren't many markings to choice...
    Which camo it needs?
    Polux
      It is the old green and brown scheme Polux.
      • Dave W
        • Jan 2011
        • 4713
        I've not built an F111 myself.Who makes this kit?.I can't quite read the manufacturers name on the instructions.
          It is made by Zhengdefu Dave a chinese firm I believe.
          • Dave W
            • Jan 2011
            • 4713
            Not heard of them so will be watching this come together.1/48 scale I presume?.
              Yep it is. A lot of internal bits n bobs to put together for the swing wing should be interesting.
                Will be interesting to see this one come together, it couldn't be worse than the academy F-111. That was a terrible kit to make. With the camo are you talking about the south east asia camo? It's a bit strange you get no stencils with the decals as the F-111 has quite a few. Do the pylons swing with the wings?
                  Kresten Looking at the destructions I think the pylons do pivot wthe the wing movement. I have already found what could be the first problem of the build. That being the forward section fit to the main body However we shall see. The camo is what was standard on most USAF airframes before they adopted the NATO grey.
                  I was a bit suprised at how few decals were with this kit seeing how big it is.
                    Ah, this is one of the main problems with the academy kit. Leaves a large gap, if you look at some builds of the academy version most people use some sheet styrene to make a rib i suppose you would call it, to expand the main body to meet the nose section. Another thing is the pivoting pylons, on the F-111 only the 2 inboard pylons on each wing would pivot. If they used the third the wings had to remain at full extension. That sounds like the normal SEA camo. Always looks good on any aircraft. The RAAF birds had a black underside though, not the usual lighter colour. Should be good to see how this goes.
                    • yak face
                      • Jun 2009
                      • 13841
                      • Tony
                      I'll be watching this one Terry , I love the look of the f111. These Zhengdefu kits arent too bad , ive got the Su 27 in 1/48 and its ok. The one area that lets them down is the decals , not very many, usually spurious in nature and with a few amusing spelling errors ('Whisperino death' for example on this one!) Ive heard that they are sometimes copies of academy kits , although the su 27 is different in breakdown so this may not be true for all. With a bit of careful fettling i'm sure it'll turn out great. One final note , anyone thinking about getting the A10 by this maker -DONT!!! steer well clear , its a real pile of ... , cheers tony
                        Thanks guys.
                        Tony I just went and checked the decals and you are right I hadn't noticed that before.
                        I might just have to look around on the net for a replacement sheet me thinks. The cockpit detail isn't the best either but as it is a closed offic I am not to worried.
                        • yak face
                          • Jun 2009
                          • 13841
                          • Tony
                          The cockpit and decals arent too hot on my su 27 either (actually the decals are for the PLAAF , i'm doing it as Russian so it doesnt matter) , the cockpit doesnt really matter either as Ive got a resin seat and i intend converting it to a Su 35 , which has a different 'glass' cockpit . Apart from this the outline and other details are very usable , the same thing should go for your F111 , and not forgetting that these kits can usually be picked up fairly cheap. Looking forward to seeing the build , cheers tony
                          • flyjoe180
                            • Jan 2012
                            • 12400
                            • Joe
                            • Earth
                            Look forward to this one Terry, as I said in another thread, the Pig is one of my favourite post war aircraft.
                              Over the last couple of I have snatched bench time where possible. The cockpit is at a point where I think I am going to leave it. The harnesses on the top half of the seats are made from paper and wire.
                              [ATTACH]72138.IPB[/ATTACH]
                              [ATTACH]72139.IPB[/ATTACH]
                              [ATTACH]72140.IPB[/ATTACH]
                              [ATTACH]72141.IPB[/ATTACH]
                              [ATTACH]72142.IPB[/ATTACH]
