Another Spitfire
    Another Spitfire
    After completing the Spitfire Mk IX Eduard now Mk Vb of the Tamiya 1/48.
    I have the Eduard PE. How not to get along very well with the PE's plan to only use safety belts and perhaps most two or three pieces.
    I have the decals for the FAP (Portuguese Air Force) but I'm still having doubts about the scheme. Once the paint is exactly the same going forward and then make a choice.
    The model.
    The sprues, PE of Eduard and decals FAP.
    Regards
    ajcmac
  • stona
    • Jul 2008
    • 9889
    Very nice Antonio, looking forward to seeing how you do this one.
    • Vaughan
      • Apr 2011
      • 3174
      Watching with interest Antonio.
        • 22770
        Looking forward to this Antonio I don't think i've ever seen one in portuguese markings
          Looking forward this one Antonio, I am building a similar one!
          Good luck!
          • flyjoe180
            • Jan 2012
            • 12400
            • Joe
            • Earth
            Nice topic, look forward to it.
              Thanks for following and for your comments.
              I started the interiors. I glued some PE's. Still do not know if I'll use the dashboard from Eduard.
              All ready to start painting.
              Regards
              ajcmac
                A very fine work Antonio.
                  Thanks Pink Phanter .
                  I painted the interior with Xf-71 Tamiya.
                  Then some work weathering to give a appearance of use.
                  Painted the pilot's seat, oxygen cylinders, wheels and rear landing gear.
                  Right now I have the interiors almost ready, just missing the seat belts from Eduard.
                  Regards
                  ajcmac
                    Nice...
                    • flyjoe180
                      • Jan 2012
                      • 12400
                      • Joe
                      • Earth
                      Yep, nice work so far
                      • Vaughan
                        • Apr 2011
                        • 3174
                        Looking good Antonio. Correct me if I'm wrong but the compressed air bottles(not oxygen) were either silver or black.
                          Pink and Panthe flyjoe180.
                          Thank you .
                          Vaughan
                          Also think so but I saw a model with them painted blue, enjoyed and experienced as after all glued they will not be visible.
                          Everything ready. Missing just glue the seatbelts.
                          Not got the decals, glued to PE.
                          Side panels.
                          With side panels ready glued the fuselage.
                          And to have it all.
                          Regards
                          ajcmac
                            Very nice.
                            I'm building the same, but the Eduard one, and I like see the difference between both models.
                            Ps: You can call me Polux (my name), if you prefer.... Pink Panther is just a nick, Antonio.
                              Originally posted by \
                              Very nice.I'm building the same, but the Eduard one, and I like see the differents between both models.
                              Polux.
                              I finished the Eduard Spitfire for about a month.
                              In terms of quality (plastic fittings) is, for me, as good as the Tamiya model. In terms of details of the model is far Tamiya, for better. The interiors look like the interior of the model of the Tamiya 1/32 scale.
                              I'm thinking of buying the Spitfire Mk. Class IX Royall and do the other two versions.
                              Regards
                              ajcmac
