I recently managed to help out fellow member Roman (Vajled) with a bottle of Klear from my stash. He very kindly insisted on reciprocating in some way and what a nice surprise it was when this kit arrived hot foot from Croatia!
I've had a quick look and it looks very nice. Like many larger Hasegawa kits a sparse interior is more than compensated by a very nicely done and finely detailed exterior which is the bit we'll see at the end
There are three decal options for two aircraft, all from No. 467 Squadron. Two for PO-S, R5868,at different times. Unfortunately the text of the decal about no enemy aircraft over the "Reich" reads "Eich"!
No problem, I will do the other option PO-V, an aircraft that was lost on the night of 02/03rd October 1943 with all her crew on a raid to Munich.
As we near remembrance day I thought it would be good to remember her typically young crew of men from around the Commonwealth.
Pilot: P/O. Robert Harder N/Z415692 R.N.Z.A.F. Age 26. Killed
Fl/Eng: Sgt. George Kenneth Barnes 546801 R.A.F. Age ? Killed
Nav: F/O. Milton Edwin Garbutt AUS/413976 R.A.A.F. Age 24. Killed
Nav 2: Fl/Sgt. Allan Walter Wright AUS/418609 R.A.A.F. Age 20. Killed
Air.Bmr: Fl/Sgt. Graham Ernest Potter AUS/410088 R.A.A.F. Age 21. Killed
W/Op/Air/Gnr: Sgt. William James Baker 1334345 R.A.F.V.R. Age 20. Missing.
Air/Gnr: Sgt. Norman Sidaway 1499834 R.A.F.V.R. Age 23. Killed
Air/Gnr: Fl/Sgt. Frank Pullom AUS/414161 R.A.A.F. Age 28. Killed
One small error with the decals for this one too. PO-V was ED621.
The serial given on the decal sheet is ED539 which was PO-P, lost with all her crew on 27/28 January 1944 over Berlin. Obviously a completely different aeroplane.
I will make a decal with the correct serial for PO-V.
It's a nice kit which I'm looking forward to building. Hopefully I'll do it justice and justify Roman's confidence, to whom thanks are due!
Poor research by Hasegawa!
