Super work Dave. What a beast, it looks stylish and menacing at the same time.
Airfix 1/48 TSR2
Well so far Ive sprayed two coats of white primer,Two coats of Vallejo White and finally a coat of Revell enamel matt white on the model .I think Ive finally managed to cover all the green filler.With hindsight,I should have used white filler but didn't have any at the time.Because the engraved detail is quite prominent,I think you could put ten coats on the model without filling them in.Just noticed a tiny hole in the filler on one of the intakes.So that will have to be delt with.There are 'T' shaped slots on the sides of both intakes.These are for plastic blobs that represent cameras fitted to XR220.As I'm finishing it as XR219, which didn't have them and was the Only TSR2 to go supersonic,these have to be filled in.For some unknown reason the nose radome has come out a different shade of white.So I will have to paint it again.Comment
[ATTACH]77012.IPB[/ATTACH]
[ATTACH]77013.IPB[/ATTACH]
That's all the decals put on.There are a lot of small stencils a couple of which are numbered wrong on the decal sheet.For anyone building this kit note that the decal placement guide calls out two no.29's.These are the canopy operating handles and there is only one 29 on the sheet.The other handle is numbered as no.21.Now I'm going to wash the model carefully and put another gloss coat on.Then I will fit the Undercarriage doors and wheels,followed by some light weathering and a final matt coat.
Attached FilesComment
She's coming along nicely Dave, you've done a good job with the white paint, I hear white can be a bit of a bitch. I'm looking forward to seeing how you tint the canopy.
I'm going to leave mine until I have a bit more experience behind me, I don't want to mess it up.Comment
Originally posted by \She's coming along nicely Dave, you've done a good job with the white paint, I hear white can be a bit of a bitch. I'm looking forward to seeing how you tint the canopy.I'm going to leave mine until I have a bit more experience behind me, I don't want to mess it up.Comment
Originally posted by \Looking fantastic Dave , I bet those walkway decals caused a few swear words! looking forward to seeing it up on its feet , chers tonyComment
