1/4 Scale SE5a ( The Old Dutch )
    Cheers Vaughn, appreciated.
    Andy
    • stona
      • Jul 2008
      • 9889
      #302
      Hiya Andy,I've just got up to date with your build. Great stuff as usual,we'd expect nothing less. It's really coming along now and looks most impressive. I'll be checking in for more!
        Thanks Steve. Hope to have some more for you all before Christmas Day.
        Andy
          Man its just keeps getting better Andy ,anxiously awaiting more !
            Thanks Trey. I will oblige shortly.
            Andy :newyear:
              Well, Christmas over and back to the workshop.
              Started to make progress on the upper wing mid section. This section also has a tank built into it so i set to the litho plate and this time embossed the rivits.
              [ATTACH]37691.vB[/ATTACH][ATTACH]37692.vB[/ATTACH][ATTACH]37693.vB[/ATTACH][ATTACH]37694.vB[/ATTACH]
              This tank section is held in place with metal straps. Litho plate was too thin for this so i cut up a pea tin left over from the Christmas Dinner, Luckily the mrs washes everything before she puts it in the recycle bin, hehe.
              I cut three strips and made the straps.
              [ATTACH]37695.vB[/ATTACH][ATTACH]37696.vB[/ATTACH][ATTACH]37697.vB[/ATTACH][ATTACH]37698.vB[/ATTACH]
              After covering the section with Solatex i fitted the straps in place.
              [ATTACH]37699.vB[/ATTACH][ATTACH]37700.vB[/ATTACH][ATTACH]37701.vB[/ATTACH][ATTACH]37702.vB[/ATTACH][ATTACH]37703.vB[/ATTACH][ATTACH]37704.vB[/ATTACH][ATTACH]37705.vB[/ATTACH]
              Andy
              [ATTACH]41829.IPB[/ATTACH]
              [ATTACH]41830.IPB[/ATTACH]
              [ATTACH]41831.IPB[/ATTACH]
              [ATTACH]41832.IPB[/ATTACH]
              [ATTACH]41833.IPB[/ATTACH]
              [ATTACH]41834.IPB[/ATTACH]
              [ATTACH]41835.IPB[/ATTACH]
              [ATTACH]41836.IPB[/ATTACH]
              [ATTACH]41837.IPB[/ATTACH]
              [ATTACH]41838.IPB[/ATTACH]
              [ATTACH]41839.IPB[/ATTACH]
              [ATTACH]41840.IPB[/ATTACH]
              [ATTACH]41841.IPB[/ATTACH]
              [ATTACH]41842.IPB[/ATTACH]
              [ATTACH]41843.IPB[/ATTACH]
                • 18271
                That looks very good Andy.
                  Thanks Ian. Hopefuly will look better with some paint on
                  Andy
                    Andy nice bit there with the tin can,you never stop amazing me !
                      Thanks Trey. Hopefully i can keep it up.
                      Andy
                      • yak face
                        • Jun 2009
                        • 13855
                        • Tony
                        #311
                        Superb bit of building andy, i just love the whole thread, the amount of work and thought thats gone into this is amazing, its a master class in using all manner of materials in unusual ways to get the desired result, Fantastic!! cheers tony
                          Thanks Tony. I have to confess that though some of the ideas i have here are great... not all credit goes to me. As i indicated earlier in this thread, i have take guidance from Grahame (Greyhead) and his build of the smaller version. He did such a fantastic job it inspired me to pick this model for my tribute build. I hope i can turn out somewhere near the same result as he did. Thanks Grahame for providing me with the insparation and fine detailed thread to follow for reference.
                          Andy
                            Progressing with this section of the upper wing... its time to make the 2 Oil Sumps that are located on the under side. Simply made from Balsa that has been cut and shaped, covered with fine cloth to stop any splitting with age and then glued to the flange plates.
                            [ATTACH]37811.vB[/ATTACH][ATTACH]37812.vB[/ATTACH][ATTACH]37813.vB[/ATTACH][ATTACH]37814.vB[/ATTACH][ATTACH]37815.vB[/ATTACH][ATTACH]37816.vB[/ATTACH][ATTACH]37817.vB[/ATTACH][ATTACH]37818.vB[/ATTACH][ATTACH]37819.vB[/ATTACH][ATTACH]37820.vB[/ATTACH]
                            Simulated stiches have been created from using fine Styrene half round section cut into short peices and glues with Canopy glue.
                            [ATTACH]37821.vB[/ATTACH]
                            Now a nice little trick. Making rib tapes that look good enough. A straight cut edge would look awful so here is a little trick. Take a Hacksaw Blade and lay it on the solartex and pulling up and across the blade tear a nice serated edge, find your desired width and do the same again. Instant rib tapes.
                            [ATTACH]37822.vB[/ATTACH][ATTACH]37823.vB[/ATTACH]
                            Now to fix the tapes with the iron.
                            [ATTACH]37824.vB[/ATTACH][ATTACH]37825.vB[/ATTACH][ATTACH]37826.vB[/ATTACH]
                            I think that it hasnt turned out too bad, a lick of paint and some weathering will set it all off lovely im sure.
                            Andy
                            [ATTACH]41938.IPB[/ATTACH]
                            [ATTACH]41939.IPB[/ATTACH]
                            [ATTACH]41940.IPB[/ATTACH]
                            [ATTACH]41941.IPB[/ATTACH]
                            [ATTACH]41942.IPB[/ATTACH]
                            [ATTACH]41943.IPB[/ATTACH]
                            [ATTACH]41944.IPB[/ATTACH]
                            [ATTACH]41945.IPB[/ATTACH]
                            [ATTACH]41946.IPB[/ATTACH]
                            [ATTACH]41947.IPB[/ATTACH]
                            [ATTACH]41948.IPB[/ATTACH]
                            [ATTACH]41949.IPB[/ATTACH]
                            [ATTACH]41950.IPB[/ATTACH]
                            [ATTACH]41951.IPB[/ATTACH]
                            [ATTACH]41952.IPB[/ATTACH]
                            [ATTACH]41953.IPB[/ATTACH]
                              The next part of this centre wing is the vent pipes that extend from the oil Tank. These travel to the rear of the section. These are made from copper tube and the clips are made from some flat brass stock that i have.
                              Andy
                              [ATTACH]42052.IPB[/ATTACH]
                              [ATTACH]42053.IPB[/ATTACH]
                              [ATTACH]42054.IPB[/ATTACH]
                              [ATTACH]42055.IPB[/ATTACH]
                              [ATTACH]42056.IPB[/ATTACH]
                                Andy,wow you're a plumber as well!? Outstanding work! Have a great New Year. Cheers Trey
