1/4 Scale SE5a ( The Old Dutch )
    • 18271
    An other way of bending the pipes with out them flattening is to fill them with fine sand then put blue tac over the ends. If you want to go to extreams, you can even fill them with 70deg low melt solder........bend heat up and the solder runs out the end. (mind your fingers).
    ( Hi Daniel, I was wondering where you had gotten to the other day and then you pop up again! Hope you are well. Drop me a line.)
      Thanks Ian, appreciated.
      Andy
        Just received my DB 1/4 SE5 and following your thread with interest. Great work.
          Its a great kit, im sure you will enjoy it as much as i am.
          Andy
            Well, Graham came up trumps, he has emailed me the clocks he used on his project and they are spot on. Thanks Graham!!!. I have moved on from the dash for a while now while im waiting for some solid nylon round section, this will be 60mm in diameter and i will work it to shape in the lathe to create the clocks.
            I made some progress today on the fuzz and will be posting some pics tonight for you all to see.
            Andy
              I promised you some pics and here they are. I have started on the fuel tank housing that also incorporates the recess for the Lewis gun. I have also worked on the Cabanes and have had to complete this work to allow the ply covering to go on... i love the squadren green and am always happy to use it when i can. as this section will be covered with litho plate there wasnt realy a need but as i said... as this is my tribute i will cut no corners on this build, only strive to improve on my previous builds.
              Hope you like the progress so far, it will get better as we go along.
              [ATTACH]29094.vB[/ATTACH][ATTACH]29095.vB[/ATTACH][ATTACH]29096.vB[/ATTACH][ATTACH]29097.vB[/ATTACH][ATTACH]29098.vB[/ATTACH][ATTACH]29106.vB[/ATTACH]
              The 16g cross peice wires are fixed to the struts by wraping round fuse wire. Anchor hooks also have to be bent into shape and bound at the same time, once in place and everything is square the top cabane is removed and the fuse wire solderd then the whole thing is removed and the bottom joints are solderd and then it is re assembled again.
              [ATTACH]29099.vB[/ATTACH][ATTACH]29100.vB[/ATTACH][ATTACH]29101.vB[/ATTACH][ATTACH]29102.vB[/ATTACH][ATTACH]29103.vB[/ATTACH][ATTACH]29104.vB[/ATTACH][ATTACH]29105.vB[/ATTACH]
              [ATTACH]34546.IPB[/ATTACH]
              [ATTACH]34547.IPB[/ATTACH]
              [ATTACH]34548.IPB[/ATTACH]
              [ATTACH]34549.IPB[/ATTACH]
              [ATTACH]34550.IPB[/ATTACH]
              [ATTACH]34551.IPB[/ATTACH]
              [ATTACH]34552.IPB[/ATTACH]
              [ATTACH]34553.IPB[/ATTACH]
              [ATTACH]34554.IPB[/ATTACH]
              [ATTACH]34555.IPB[/ATTACH]
              [ATTACH]34556.IPB[/ATTACH]
              [ATTACH]34557.IPB[/ATTACH]
              [ATTACH]34558.IPB[/ATTACH]
              • yak face
                • Jun 2009
                • 13855
                • Tony
                #112
                Just amazing andy, the work going into this is unbelievable, keep it up mate, cheers tony
                  Thanks Tony, appreciate your kind words.
                  andy
                  • spanner570
                    • 15443
                    #114
                    Andy, I've been quietly following this from the off....Your personal reason for doing it and the work itself.
                    You are one top bloke and no mistake.
                    Ron
                      Ron, Thank you for your kind words and thoughts. I have my heart in this build and it should be my best ever work, past and future. If i never build another as good as this i wont mind. I have already decided that some of the work on the dash is rubbish and will be re-doing it again. I have found a small 1 man company that can do the fuel selector and clock lables on proper trafalite and engrave it for me. The clocks i have coverd thanks to Graham and i have sourced the materials for the clock housings. In the end the dash should look a million times better.
                      Thanks again.
                      Andy
                        Andy some great looking progress. Do you use an incedence meter on the wings? I've built a few Rc Bipes and that was always a challenge when soldering the top support wires.
                          Trey, i have been lucky with this one as all of the cabanes are premade, its just a case of putting it together. I hope they have got it right lol.
                          Andy
                          • colin m
                            • 8771
                            • Colin
                            • Stafford, UK
                            #118
                            Andy, your build is quite amazing. The drive needed to undertake a project like this I suspect is beyond me, but I really look forward to continuing to watch this develop.
                            Regards
                            Colin M.....
                              Thanks Colin. This one is special to me and will be beyond my limits but for the very reason i am building it i know that i can pull it off.
                              Thanks
                              Andy
                                Well, i spent this week doing a little metal work. I covered the Fuel tank with litho plate and 2mm rivits. The rivit lines are deliberate to add that extra bit of scale. The panels of the tank fall short, this is because there is another panel that overlaps this and i will make it later on. The fuel filler cap is made out of the good old evergreen styrene and is painted to give it that old tarnished brass look. From here i will now concentrate on making the clocks as i have managed to find some nylon round section bar at 60mm diameter. Now i get to use the lathe for the second time in 2 years lol. It might sound expensive to have brought it and only used it once but its a valuable peice of kit to own because if you need to make parts like this, a lathe is worth its weight in gold.
                                Hope you like it so far.
                                [ATTACH]29269.vB[/ATTACH][ATTACH]29270.vB[/ATTACH][ATTACH]29271.vB[/ATTACH][ATTACH]29272.vB[/ATTACH][ATTACH]29273.vB[/ATTACH][ATTACH]29274.vB[/ATTACH][ATTACH]29275.vB[/ATTACH][ATTACH]29276.vB[/ATTACH]
                                Andy
                                [ATTACH]34717.IPB[/ATTACH]
                                [ATTACH]34718.IPB[/ATTACH]
                                [ATTACH]34719.IPB[/ATTACH]
                                [ATTACH]34720.IPB[/ATTACH]
                                [ATTACH]34721.IPB[/ATTACH]
                                [ATTACH]34722.IPB[/ATTACH]
                                [ATTACH]34723.IPB[/ATTACH]
                                [ATTACH]34724.IPB[/ATTACH]
