Doing a great job Dave
1/48 Boulton-Paul Defiant
I've put the radiator together and glued it to the model.There are no locating pins or any indications as to where it fits.So just had to place as per a pic in the instructions.It doesn't fit properly so I've got some more filler to sand.Ive also started the laborious task of masking the vacuform canopy.I'm doing this before cutting the canopy out of the clear sheet as it's more rigid and easier to work on this way.Comment
Originally posted by \This is coming along really well Steve. I shudder at the thought of that vacformed canopy though and trying to get it accurately cut.......Comment
Originally posted by \I never realised how big the turret on these aircraft was , the hole for it is huge! No wonder the performance suffered it must have weighed a ton! tony
The Defiant was intended to attack unescorted bomber formations and may well have been quite good at that. Nobody was expecting France to fall and for the Luftwaffe to acquire bases just across the Channel which it could use to escort its bombers with single engine fighters. That spelt disaster for the Defiant as a day fighter but it soldiered on and made the best of a very bad job as a night fighter and in some other roles.
A rather optimistic and factually inaccurate view of the type, and some nice film here.....
SteveComment
Originally posted by \Cutting it out is a case of patiently and repeatedly scoring around it untill it comes away from the sheet.I find a sharp pair of nail scissors give you a lot more control when cutting out vacuformed parts.by the way,I'm Dave.Comment
I've painted the PE seat and installed it along with seat belts and PE armour plate.The instructions show the shoulder straps attached to the hole in the seat back.Theres also a hole in the armour plate.Ive placed then in the plate whilst I decide what to do.I can't find any cockpit close ups on the net so will probably attach them to the armour as they are way too long when fixed to the seat.Ive also cut out the canopy.Ive placed it on the model to see what it looks like.Rather a thick frame below the windscreen.I can trim a bit more off along the bottom edge,but not much.So I am just going to have to live with it as I can't find a replacement on the net.The kit comes with resin guns for the turret.The barrels of which don't look very good.So I've ordered some 'Master' turned brass barrels from Hannants this morning.The turret is a focal point of the model so it will be a worthwhile improvement I think.Comment
Originally posted by \590lbs with guns, ammunition and oxygen equipment for the gunner, not a ton but heavy enoughThe Defiant was intended to attack unescorted bomber formations and may well have been quite good at that. Nobody was expecting France to fall and for the Luftwaffe to acquire bases just across the Channel which it could use to escort its bombers with single engine fighters. That spelt disaster for the Defiant as a day fighter but it soldiered on and made the best of a very bad job as a night fighter and in some other roles.
SteveComment
Canopy glued on.I found a walk around of a Defiant on You tube that shows the pilots shoulder straps attached to the armour plate behind the seat.So that's where I've fitted them.ive also rescribed some lost detail on the fuselage.The I fitted the PE representations of landing lights to the wing Leading edges.Will cut out and fit the vacuform landing light covers to the wings next.Comment
