I've just cut the vacuform landing lights out and glued them to the wings with 'Gators Grip'.Two spares are supplied in the kit.But I managed to cut two out without messing up.
1/48 Boulton-Paul Defiant
Tonight I've scribed the flap detail on the undersides of the wings.i marked them out with black pen first to make it easier.Then I spent ages masking the turret transparency and finally I cut out the slots for the guns.Now I'm going to cut it away from the backing sheet.Comment
You are making a superb job of this. it is so good to see real modelling skills at work rather than relying on expensive kits that do everything for you.Comment
Originally posted by \That masking job alone would make me shiver Dave , never mind having to cut out the gun slots and cut it off the vac form sheet!!! Keep at it mate , I think its yeilding! cheers tonyComment
Superb work Dave, I love seeing older/short-run kits being tamed. You probably already know this but Classic Airframes re-tooled their Defiant kits in 2004 and they came with injection moulded clear parts and lots of resin for the cockpit and wheel wells, worth searching for if you fancy anotherComment
