Airfix 1/72 Zero Starter Set
  • monica
    • Oct 2013
    • 15169
    #16
    hi joe thank you , ta for the info will see if i can find some think on it,
    on a light note why the colors are so hard to work out on Japanese plains is they were never in the war ops:
      Thanks
      Havent made much progress as I have been busy with other things
      The flash has made the engine look a lot more silver than it is.
      • monica
        • Oct 2013
        • 15169
        #18
        looking good see your done a little chipping along the leading edgers, have the same happen as well some times the color seen alot brighter than it is
        keep up the good work
          I think you can also see some preshading at work here. Although now I think another thin coat of paint may have been in order. No going back now though, I think the varnish and weathering will help dull the effect a little.
          • monica
            • Oct 2013
            • 15169
            #20
            looking good and yes you can still see the preshading, well i do think that is a very close color, what did you use ?
              Thanks Monica. Its actually just the Humbrol 90 acrylic that came with the kit. It looks much better in the above photo taken without a flash. Should have this finished in the next few days I think.
              • monica
                • Oct 2013
                • 15169
                #22
                thank you for that will make a note off it,
                  • monica
                    • Oct 2013
                    • 15169
                    #24
                    real nice she turned out well,like the shading as also ,
                    i use a fine pair off nail nippers the type you get in the chemist , just smaller and finer than small side-cutters
                      Thanks Monica. Hope to weather and varnish it tomorrow.
                      I have decided to give the panel line wash a miss, as they are quite deep anyway on this kit, and quite visible.
                      With regards the parts that were snapped. I actually found them already snapped on the sprue when I came to remove them. The plastic on that corner seemed quite brittle. No biggy as I have managed to replace them with something passable I think
                      • flyjoe180
                        • Jan 2012
                        • 12426
                        • Joe
                        • Earth
                        #26
                        Looks good
                          That's looking real nice so far, you've done a good job of making it look "used".
                            Yep, looking very good. This is turning to be a popular wee model, I reckon - I really enjoyed this one too. Also broke pitot tube before finishing it!
                              I had actually looked at your thread previously Alasdair, and it helped me decide on going with the Humbrol 90.
                              The little trim tabs on the wings are fiddly, but this is how I do mine. I squeeze some white tack onto a cocktail stick, and use this to pick up the small part, orientated in such a way that it can be fitted. I put a dab of glue on some card, and lightly dab the part onto the glue. Then I position it on the aircraft in the right place, and the glue should (after a few seconds) have more stick than the white tack, and you can just gently pull it away.
                              Hope that explanation makes sense!??
                              Well, this one is nearly finished now. I only went for subtle soot staining, as this aircraft was only a couple of weeks old when used at Pearl Harbour, so wouldnt have been as battered as we are used to seeing a Zero portrayed. I didnt do a panel line wash as the lines are deep, and the preshading is sufficient I think.
                              • monica
                                • Oct 2013
                                • 15169
                                #30
                                yep she is a great build i do like it alot,as you said they were new when hitting Pearl,
                                i real like the shadow lines did you do them with a black pen ?
