Me bf 109 F4 Trop. 1/32
    This is next on the list. The new kit from Hasegawa also in 1 / 32 scale. Me 109 F4 Trop.
    I am almost done with the Tamiya 1/48 109 E Trop, the motling was "interesting" to say the least. Lucky the G had a simpler seeme !
    Looks like a realy nice kit, I rather like the nice touch of the crewman.
    Keep the pix comming.
    Theuns
    • stona
      • Jul 2008
      • 9889
      Originally posted by \
      I rather like the nice touch of the crewman. Theuns
      Hi Theuns,that's H-J Marseille. The figure is based on a picture of him watching another victory mark being applied to the rudder of his aircraft. He does indeed wear a rather splendid pair of shorts,reminiscent of a tea clipper in full sail!
      I've got one of these planned so I'll be keeping an eye on Antonio's progress.
        I have been reading up on this plane (yellow 14 109-4/trop) and interestingly in the book "aircraft of the aces - Me 109 aces of narth Africa and the Med" it shows his plane with the half blue/ brown fuse (wn 12 593) aswell as a 109 (wn 14 256) but with the brown almost all the way down the fuse.
        What collour uniforms did the Med groundcrew wear Steve?
        I am looking into getting a 1/48 109 G to do as the SAAF captured/restored plane with the side # ?-AX, it should go nicely with my German 109E "black 8"
        Pardon the hijack......
        Theuns
          • 18266
          I recall seeing a picture of Hr Marseille in something looking very Afrika corp colour.
          • stona
            • Jul 2008
            • 9889
            I recall seeing a picture of Hr Marseille in something looking very Afrika corp colour. Ian M
            I agree,most photos seem to show desert type uniforms. The ground crews also seem to be in this colour rather than the black overalls of the ETO. They are often pictured wearing not much more than shorts and these are either in a desert colour or black.
            I'll be home (briefly) tomorrow morning and can access my references for Marseille. I've got quite a lot of detail on all his known aircraft. The one with the low demarcation line was repainted,in theatre,prior to Marseille receiving it and has several interesting little anomalies. If you are you planning to do a Marseille aircraft maybe we should start another thread so that Ajmac can build his here!
              I started the model.
              Eliminated panel lines that do not belong to the F4 and injection marks. The interior is ready to begin painting.
                That's a lot of detail in that cockpit. Beautifully put together and is going to look stunning with some paint on it.
                  Interior painted with RLM66.
                    A small advance. The pilot's seat is not attached because I need to paste the seat belts. We still lack the dashboard and a piece I do not know the color.
                    • stona
                      • Jul 2008
                      • 9889
                      Good stuff Antonio. I see you are building this Hasegawa kit and the Trumpeter one at the same time. Leaving the accuracy issues (particularly Trumpeter's) aside do you have an opinion as to which is the best to build?
                        Good stuff Antonio. I see you are building this Hasegawa kit and the Trumpeter one at the same time. Leaving the accuracy issues (particularly Trumpeter's) aside do you have an opinion as to which is the best to build?Cheers
                        I hope you can understand what I mean .
                        Hasegawa Models, as everyone knows, are good. In the case of the Me 109 F4 is an easy kit to build, with good fittings, interior fuselage and wings very detailed. Trumpeter's model, for me, with good fittings, with more detail, despite knowing that many of these details will no longer be seen. Furthermore, I have solved the problem of the rivets.
                        I am finishing Dauntless and I think he's very good. The pity is that Trumpeter has no more accuracy, as in the Bf 109 F4 and other models, often make so many errors.
                        I really like the models from Hasegawa, but I think that I'm a fan of the Trumpeter models.
                        • stona
                          • Jul 2008
                          • 9889
                          Thank you Antonio,and I understand you perfectly well. I've recently built a couple of Trumpeter kits myself and I have to agree that they are very detailed and very well engineered. I think that the Trumpeter 1/32 Me262 is by far the best kit available in this scale.
                          I may build the Hasegawa Bf109F myself soon. The Zoukei-Mura Ta152 I'm building now is not a particularly easy build so the Hasegawa kit maybe just what I need to recover,something nice and easy!
                            I'm a little because I'm still waiting for Eduard masks. My view is no longer what it was and isolate the glass from Hasegawa is not easy. Already got them to arrange. They should be here next week.
                            Went ahead the service by painting a small piece missing inside.
                            I glued the fuselage.
                            I painted the landing gear and flaps.
                            Now is to complete the instrument panel and glue the interiors.
                              The masks ready.
                              Fuselage and wings glued.
                              Seatbelts.
