Revell 1/32 Bf109 G-6 Early/Late
  • Vaughan
    • Apr 2011
    • 3175
    Hi All
    Here is my next build. This is a new tooling brought out late last year and I picked this one up from Wonderland Models for under £20.
    As it says on the box you are able to build two versions and they supply engine cowlings,canopies, treaded and smooth tyres and high and low tails. There is also options for different ejector shoots for the armament. The decal sheet looks to be in good registration although the black areas seem a little mottled and not solid unfortunately this is not visible in the photo. I will have to wait and see if this shows up once applied fingers crossed it doesn't.
    As you can see from the spru shots there is some very fine detail down to the point that they supply the fuel line as a clear part. One thing Revell has finally picked up on and what people have moaned about for a long time is the lack of RLM numbers well here they are for the first time
    Not sure when I will be able to start on this one as my work station is not completely sorted. So watch this space[ATTACH]80700.IPB[/ATTACH]
    [ATTACH]80701.IPB[/ATTACH]
    [ATTACH]80702.IPB[/ATTACH]
    [ATTACH]80703.IPB[/ATTACH]
    [ATTACH]80704.IPB[/ATTACH]
    [ATTACH]80705.IPB[/ATTACH]
    [ATTACH]80706.IPB[/ATTACH]
    [ATTACH]80707.IPB[/ATTACH]
  • Richi72
    • Sep 2013
    • 1100
    Nice one Vaughan,
    will follow this one.
    Cheers Richi
      I was going to build this one Vaughan, but I chickened out! I'll pull up a chair
      Patrick
      • tr1ckey66
        • Mar 2009
        • 3592
        Hi Vaughan
        This is another kit I have waiting in the stash. I'll be interested to see this coming together and the decal options you go for.
        Paul
          • 18271
          Count me in as well. I too have one in the stash, yes you read correctly I have a German aircraft in the stash! (three actually :-P )
          I wont be building mine for a while so I will watch and learn.
          • monica
            • Oct 2013
            • 15169
            Hi Vaughan, and I ,will be watching for the side lines,
              Well that is a surprise 1/32 Vaughan ! Where do you put them all I am running out of space with 1/48. Interesting as it does seem that when you get into a scale you do not on average change
              As you say lots of detail and that page with all the colours etc looks as though you will be kept busy.
              Fascinated with Barry's camouflage and will be interested to have your technique when that part comes around. It looks to me as if the camouflage is the most difficult.
              • Dave W
                • Jan 2011
                • 4713
                Looks a nice kit.Fantastic value for money like all Revell's new releases.
                • Vaughan
                  • Apr 2011
                  • 3175
                  Well at last I've made a start and predictably with the office. This comes with over 15 parts and also that fuel line in clear plastic. No problems with construction all very straight forward. I've used the decal for the instrument panel as there is no dial detail within each dial so the decal sits perfectly flat. The seat belts are HGWs a little fiddly but worth it and at £6.20 for two sets plus PE parts you get a lot for your money. Toe straps are made from foil.
                  [ATTACH]82353.IPB[/ATTACH]
                  [ATTACH]82354.IPB[/ATTACH]
                  [ATTACH]82355.IPB[/ATTACH]
                  [ATTACH]82356.IPB[/ATTACH]
                  [ATTACH]82357.IPB[/ATTACH]
                  [ATTACH]82358.IPB[/ATTACH]
                  [ATTACH]82359.IPB[/ATTACH]
                  [ATTACH]82360.IPB[/ATTACH]
                  [ATTACH]82361.IPB[/ATTACH]
                  [ATTACH]82362.IPB[/ATTACH]
                  • Alan 45
                    • Nov 2012
                    • 9833
                    Very nice Vaughn and your off to a great start I do like revels 1/32 aircraft so I'll be keeping an eye out for this one
                      what a cracker of a kit and a beautiful job on the cockpit.
                      scott
                        • 18271
                        Very nice cock pit.
                        • flyjoe180
                          • Jan 2012
                          • 12433
                          • Joe
                          • Earth
                          Very nice work Vaughan.
                            Office looks top notch Vaughan!
                              Having just completed that kit I wish you lots of fun. It *is* a nice kit. Be sure to read up on the different options though as Revell went all out as far as the fuselage goes. Depending on what machine you want to build (G-5, G-6, G-10, boost or no, Mg 108 etc) different access hatches have to be filled and sanded! Have a look: http://forum.largescalemodeller.com/topic/1238-132-messerschmitt-bf-109g-6-early-and-late/ and http://forum.largescaleplanes.com/index.php?showtopic=46590
                              Sent from my SM-N9005 using Tapatalk
