German but different. Do 27 'Serengeti'
  • stona
    • Jul 2008
    • 9889
    I have a couple of weeks break in my current job so I'm going to make a start on this.
    It's a kit showing its age. A few sprues of not very finely detailed and not particularly well molded parts might mean that there will be unexpected fun to be had!
    A sample sprue.
    The clear parts look okay.
    The instructions provide cut out masks to mask the black stripes, which would mean spraying white over black. That's not going to happen, we'll see how I get on later
    • 18271
    Cool! Some thing very different from your hanger Steve.
    As for spraying White over Black, give it a try, you might be pleasantly surprised. I have done it with Vallejo model color's and has worked rather well.
      This will be an interesting one! Good luck Steve!
      • stona
        • Jul 2008
        • 9889
        Originally posted by \
        Cool! Some thing very different from your hanger Steve.As for spraying White over Black, give it a try, you might be pleasantly surprised. I have done it with Vallejo model color's and has worked rather well.
        Not for me! I know I can cover white with one nice light coat of black, or rather very dark grey in this case. The last thing I want is to spray multiple coats against so much masking. I know I'll end up with all sorts of secondary problems.
        • Gern
          • 9226
          Couldn't you copy the masks and print them out as decals? Black decals should show as dark grey when put on a white surface.
          Gern
          • stona
            • Jul 2008
            • 9889
            Couldn't you copy the masks and print them out as decals? Black decals should show as dark grey when put on a white surface.Gern
            Could do Dave but I don't see a problem with masking. I've either got to cut out the kit masks and spray in what for me is just the wrong order or mask the white and spray the black. Either way I'm going to be doing a lot of masking, but at the end of the day it's only two colours!
            Spraying the black gives me the option to vary, weather and fade it. This aircraft was in Africa after all.
            • monica
              • Oct 2013
              • 15169
              some think diffidence and interesting, will be watching this one,Steve,
              like to see how you do the camo, which way around you go
              • Alan 45
                • Nov 2012
                • 9833
                You know I wouldn't even notice this in a shop but I have learnt on here that many of the builders can make anything look great so it gives me an option if I fancy something different so I'll be keeping an eye out for this and see how it comes out
                • flyjoe180
                  • Jan 2012
                  • 12433
                  • Joe
                  • Earth
                  Nice choice Steve, something a bit different and colourful for your collection. Know what you mean about white on black, you get ridges after so many coats when the masking is removed.
                    Very interesting choice Steve, and nice to see you are building again as well will follow this thread
                    Regards
                    • tr1ckey66
                      • Mar 2009
                      • 3592
                      Hang on, this isn't a WW2 aircraft! What's going on???!!!
                      This certainly is a departure from the norm Steve. I have to admit to never having heard of this aircraft. Looks very interesting though bit like a more modern Storch.
                      It'll be interesting seeing this older kit coming together and will no doubt be another Stona success.
                      Cheers P
                        Interesting choice Steve and a dainty looking craft. The clear parts look good quality compared to my present Merlin build.
                        Just a thought does this belong to the zebra species ?
                        • stona
                          • Jul 2008
                          • 9889
                          I guess it does. Michael Grzimek allegedly painted it this way so that it wouldn't scare the animals of East Africa so much, but I doubt that worked. Grzimek was killed in this very aircraft in 1959 when he crashed following a bird strike.
                          His father was one of the original post war 'conservationists' following a colourful career in the 3rd Reich
                            Yes joking apart I wondered what the reason was although your description/explanation is very funny ?
                            • stona
                              • Jul 2008
                              • 9889
                              I have made a start believe it or not.
                              The fit is terrible, the parts are badly formed and covered with flash, I was going to pose the aircraft with some open panels but the interior is an afterthought and the engine is a mostly formless piece of plastic! It's a kit that is definitely showing both its age and that this version was not the original one.
                              I'll be doing it zipped up once I've beaten it into some kind of shape, though there are quite a few large (and ill fitting) windows through which the rather sparse interior will unfortunately be visible
                              I'll post some piccies when I get some light tomorrow.
