This is my next build.Its the G-2 tank busting version of the infamous 'Stuka'.I will be doing it as an aircraft flown by Hitlers most decorated pilot and probably the most successful combat pilot in history,Hans Ulrich Rudel.The kit comes with decals for two of his aircraft.Ive bought an Eduard cockpit detail set.I only intended to get a seat belt set .But this set was only £4 ish and includes belts and a rather nice coloured instrument panel.Ive also got some turned brass barrels for the 37mm underwing cannon.These are very impressive and far better than the kits plastic items.So here are the usual sprue shots.Ive made a start spraying the cockpit parts with primer,then Vallejo RLM66.
Hasegawa 1/48 JU87G-2 'Stuka'
I've spent the last two evenings assembling the cockpit and adding the PE to it.I haven't bothered with the tiny levers as I can hardly see them.And when I've fitted then on previous models I've always manage to knock them off!.Going to glue the fuselage together next.Comment
