This is the sea hurricane kit but I have a 1/48 hurricane MK IIC so I'm going to swap the bits out and turn it into a MK I so I can finally build Bader's hurricane
I've solved my problem with shallow panel lines after the excellent advice from you guys and talking to people at the show yesterday[ATTACH]82821.IPB[/ATTACH]
Now what I have done is pre-shade it with a thin brush to limit the over spill and leave to dry , then I have dry brushed the panel lines and then brushed the rest with a little bit more paint on the brush but not as dry as with DB , you must DB the line once do not go back over the same area as this will cause the paint to pull leaving a mottled effect , after each coat you must leave it to dry completely and this won't take long as it's only thin layers going on
I was going to do more coats but I thing leaving it as in the pic it has left a rather good weathered look
This piece has had four coats
