Spitfire Mk.XIX - Airfix 1/72
    Dear mates, I'm back.
    This time we have a simpler model as I need to recover from the fatigues of the MH-53e. I will assemble the kit strictly (almost) OOB and concentrate to make (learn to) a clean build/paint job.
    The kit is nice despite the deep grooves, ehm, panel lines, with lot of (simple) details. I did a check with a couple of walkaround and all the air intakes and bulges are at their place. Only drawbacks I can see til now are the plain instrument panel and the gear legs moulded with the panels.
    [ATTACH]83746 [/ATTACH]
    This is the cabin interior, almost all the bits are there, though in a simplified version.
    [ATTACH]83747 [/ATTACH]
    Fit is not bad at all.
    [ATTACH]83748 [/ATTACH]
    So I started with the cockpit, recreated the IP, added camera trigger and compass, the moved to the seat, which I sanded to make it thinner, and to which I added the rocket holder, adjustme lever and cushions.
    On the cabin I added the camera control box, the first aid kit, the tool to break the canopy and some plumbing. Behind the pilot I've added the three oxygen tanks and the apparatus to remove humidity.
    Now I have more or less this:
    I also glued the three camera glasses, but still thinking how I should reproduce the lens inside, especially because only two cameras could be mounted at one time and one should be closed (with a red cover?). Any suggestions is appreciated.
    Now I started working on the wings, cutting the ailerons and completing the wheel wells which have no walls nor ribs.
    Thanks for looking,
    Francesco
    Don't know if it's just me, but the pictures aren't showing Francesco
      I. have the same problem with other threads and thought it was Tapatalk.
        Same here, no images on this or most other threads:-(
        • flyjoe180
          • Jan 2012
          • 12390
          • Joe
          • Earth
          Yeah no piccies on my screen either.
          • monica
            • Oct 2013
            • 15169
            the same no pics,
            • john i am
              • Apr 2012
              • 4019
              Sorry no pics
                There must be an issue here, John I can't see pics in your thread too
                  Now these are posted from Dropbox
                  Edit: should be fixed now
                    Arrggghhh...no pics!!!
                    We want pics!!
                      lol this is funny cos' the pics in the 2nd post are actually there...
                      john
                      • flyjoe180
                        • Jan 2012
                        • 12390
                        • Joe
                        • Earth
                        Yeah, I can see the Dropbox ones but nothing in the first post. The forum is undergoing maintenance I think, may be something to do with that?
                        • eddiesolo
                          • Jul 2013
                          • 11193
                          Got the second lot of piccies, but not the first-looks like another great build in your tiny scale Francesco.
                          Si
                            • 22770
                            Great start Francesco ( I can only see the second set of pictures )
                              Now it looks that after I've replaced last two pics from Dropbox in the first item the original uploaded to Tapatalk are showing. Weird
