nice look spit there Francesco., looking good
Spitfire Mk.XIX - Airfix 1/72
Rudder and elevator: on
Propeller: on
Landing gear: fixed and on (dry)
Exhaust pipes: on
Smoke: on
[ATTACH]84176.IPB[/ATTACH]
[ATTACH]84177.IPB[/ATTACH]
Thank you mates for your comments,
Francesco
Dear mates,
I just received the ziperboost's slipper tank, painted it in medium grey and now is ready for wash.
[ATTACH]84344.IPB[/ATTACH]
Here's how it looks on the model
[ATTACH]84345.IPB[/ATTACH]
I gave the model another layer of gunze clear but surface is still not as smooth as I expected.
Hooks for tank release still to be done. Then I just have to glue the herls and decide if I mount the tank.
Francesco
Looking real good but didn't you say at the start it would be pretty much oob, I can't imagine what you would consider heavily detailed. Really well done and in that scale great eyesight, I could only dream of that.Comment
Very nice Francesco. What are the white inserts in the wheel bays ?
Is this the Spitfire with the twin props ?
LaurieComment
Hello mates,
Thank you very much for your comments.
@Laurie,
The white bits on the bulges (fuel booster pumps) are the draining pipes, did forget to paint them.
The XIX had a single propeller.
FrancescoComment
Looks great Francesco.
Increasing the number of blades on a propeller is one way of improving power absorption through propeller solidity (the solidity of the spinning disc). When you consider that the Griffon 65 as seen in the Spitfire Mk.XIX could put out almost 2,000HP, that is nearly twice what the early war Merlins could produce. That is why you see an increase in blades as the type developed with more powerful engines. Later, contra-rotating propellers did the same thing, but also reduced torque effects as they turned in opposite directions. An interesting fact is that many pilots struggled to control the later aircraft on take off due to the massive torque produced from these enormous engines. More than one experienced Spitfire pilot came to grief because the Griffon actually turned the propeller the opposite direction to the Merlin (anti-clockwise as viewed by the pilot). Wrong pedal and full power = significant loss of ground control.Comment
Originally posted by \Every day is looking much better!!You have nearly finished
But now yes, it's done.
The target (clean build) has not been fully achieved but at least it took less than 8 work sessions to complete it and I'm overall satisfied.
Since last time you've seen it I just glued the slipper tank, wheels and antenna, plus one layer of matt clear.
Here are the pictures.
[ATTACH]84537.IPB[/ATTACH]
[ATTACH]84538.IPB[/ATTACH]
[ATTACH]84539.IPB[/ATTACH]
[ATTACH]84540.IPB[/ATTACH]
[ATTACH]84541.IPB[/ATTACH]
[ATTACH]84542.IPB[/ATTACH]
[ATTACH]84543.IPB[/ATTACH]
[ATTACH]84544.IPB[/ATTACH]
[ATTACH]84545.IPB[/ATTACH]
Originally posted by \Looks great Francesco.Increasing the number of blades on a propeller is one way of improving power absorption through propeller solidity (the solidity of the spinning disc). When you consider that the Griffon 65 as seen in the Spitfire Mk.XIX could put out almost 2,000HP, that is nearly twice what the early war Merlins could produce. That is why you see an increase in blades as the type developed with more powerful engines. Later, contra-rotating propellers did the same thing, but also reduced torque effects as they turned in opposite directions. An interesting fact is that many pilots struggled to control the later aircraft on take off due to the massive torque produced from these enormous engines. More than one experienced Spitfire pilot came to grief because the Griffon actually turned the propeller the opposite direction to the Merlin (anti-clockwise as viewed by the pilot). Wrong pedal and full power = significant loss of ground control.Comment
But during normal especially high constant speed flight at full throttle, why doesn't the fuselage permanently spin (roll) in the opposite direction to the spinner? Could the answer be that the pilot has to keep the ailerons always adjusted in a position to counteract that roll? If so, the added air drag must slow the plane down considerably.
Added:
Also, I would think that despite counter-rotating props, the torque applied by the engine to the spinner (and the reverse reaction torque by the spinner) would still be there unchanged.Comment
