Monogram, 1/24 Huey.
    • 22770
    #31
    Great work so far Si
    • eddiesolo
      • Jul 2013
      • 11193
      #32
      Ta Ian, having a few issues with the wiring at the moment...hopefully should be sorted soon.
      • Snowman
        • Oct 2014
        • 2098
        #33
        Ahhh seee the LIGHT!!
        Looking good, Si!!
        I have faith in your skills!!
        • eddiesolo
          • Jul 2013
          • 11193
          #34
          Looking good, Si!!
          Hmmm...faith...skills...be better off just getting a load of glue and the model and throw it in a bucket and see what sticks lol.
          • eddiesolo
            • Jul 2013
            • 11193
            #35
            Right. There is a update but no piccies yet. I have added some internal work, fire extinguisher to rear wall, a small first aid box next to seat a blanket wrap on the opposite side, also added a small first aid pouch to inner frame wall. All these items are from the bits box and are 1/35-but they fit superbly.
            I have also added some under window door grab handles-these are from the original USS Enterprise model...surprising what you can use.
            I have also added some decals to the pilots arm and helmet-red-crosses (1/76 scale after-market decals) on a white roundal. The doors have larger red crosses on white roundal and have added other decals-some would not go on right despite-microsol, decal fix (squeezed and the nipple end came out and I got a model full of decal fix!).
            So, have left it for tonight before I swear anymore and the Police are called
            • eddiesolo
              • Jul 2013
              • 11193
              #36
              UPDATE:
              Some piccies of what I have done so far.
              Added a first aid box and blanket wrap to either side if the rear bench seat, a small first aid pouch fastened to the floor/roof brace, also a fire extinguisher to the rear bulkhead.
              Decals applied to the pilots sleeve and helmet.
              Aftermarket decals applied to fuselage, terrible decals to apply.
              Doors decalled and glazed, grab handles fitted courtesy of USS Enterprise warp nacelles.
              Rear engine exhaust given a burnt look and also added some mesh inside to hide the wiring.
              Found a litter carrier that will be fastened to the side.
              Si
              [ATTACH]109157.IPB[/ATTACH]
              [ATTACH]109158.IPB[/ATTACH]
              [ATTACH]109159.IPB[/ATTACH]
              [ATTACH]109160.IPB[/ATTACH]
              [ATTACH]109161.IPB[/ATTACH]
              [ATTACH]109162.IPB[/ATTACH]
              [ATTACH]109163.IPB[/ATTACH]
              [ATTACH]109164.IPB[/ATTACH]
              [ATTACH]109165.IPB[/ATTACH]
              [ATTACH]109166.IPB[/ATTACH]
              [ATTACH]109167.IPB[/ATTACH]
              [ATTACH]109168.IPB[/ATTACH]
              [ATTACH]109169.IPB[/ATTACH]
              [ATTACH]109170.IPB[/ATTACH]
              [ATTACH]109171.IPB[/ATTACH]
              [ATTACH]109172.IPB[/ATTACH]
                Nice work Si like it so far.
                scott
                • flyjoe180
                  • Jan 2012
                  • 12381
                  • Joe
                  • Earth
                  #38
                  Great stuff Si, looks awesome so far. May I suggest painting that mesh black, would hide both it and the wiring as the exhaust is a straight through tube on the UH-1.
                  • eddiesolo
                    • Jul 2013
                    • 11193
                    #39
                    You're correct Joe, I will see if I can hide it a bit better. You can see the wiring if you peer into it, no other way to wire it...hence the mesh.
                    Glad you like it so far.
                    Si
                    • flyjoe180
                      • Jan 2012
                      • 12381
                      • Joe
                      • Earth
                      #40
                      If you spray it will it hurt the wiring? Turbine exhausts are always black inside. Kerosene is filthy. But warm and comforting on a cold night
                      • eddiesolo
                        • Jul 2013
                        • 11193
                        #41
                        The wiring is behind the mesh so should be able to brush black.
