Revell 1/48 Mil Mi 24 hind D crash dio
  • Alan 45
    • Nov 2012
    • 9833
    well I've decided to expand on my burnt out tank and go full throttle on some serious damage
    The idea is a crashed Mil Mi 24 in Afghanistan shortly before the Russians left and it's been there a while so it's been stripped , it's not a burn out more like a crash landing so most of its intact but with rips in the fuselage and such .
    I will be showing how it's easier to cut and damage a surface using a grinder , maybe many of you know this technique already but I can't find if its been done on here before so I thought I'd share the technic with you
    The kit is straight forward and not a lot of parts , it's the rebox of the old monogram kit and as such it's got raised panel lines so it's perfect to destroy
    Here's the sprues and such [ATTACH]108349.IPB[/ATTACH]
    [ATTACH]108350.IPB[/ATTACH]
    [ATTACH]108351.IPB[/ATTACH]
    [ATTACH]108352.IPB[/ATTACH]
  • john i am
    • Apr 2012
    • 4019
    Wow nice idea Alan I want to see the grinder you will be using
    • spanner570
      • 15404
      I'm in. I still like a good grind!
      • Alan 45
        • Nov 2012
        • 9833
        As if by magic [ATTACH]108353.IPB[/ATTACH]
        these grinding tip you can get from any hardware shop these cost me £3/4 and you get four in a pack
        Next you select where you want your damage and it's best to go from the inside as this will slip a bit so by doing it inside it stops any unwanted damage to the outer surface
        [ATTACH]108354.IPB[/ATTACH]
        You then move it up and down / side to side depending on where you want the damage [ATTACH]108355.IPB[/ATTACH]
        keep holding it up to the light until you can see the light coming through
        [ATTACH]108356.IPB[/ATTACH]
        If you look on the other side you will see a line , this is great to use as a guide to get a vice jagged line like ripped aluminium
        On something like this a helicopter or airplane it's best to line up the fuse so you get a match on both sides
        • john i am
          • Apr 2012
          • 4019
          Mmmm tools of destruction I'm sure I've got some bits like this in a dremmel set somewhere might have to go rummaging.Nice work there Alan I can think of no better demise for raised panel lines
          • Alan 45
            • Nov 2012
            • 9833
            Cheers John
            [ATTACH]108375.IPB[/ATTACH]
            The more area you thin the more bending of edges and damag you can do for this one though I want a tear like it has weekened over time by the weight of the tail causing a tear down one side but only a little on the other side like this [ATTACH]108376.IPB[/ATTACH]
              I am liking the sound of this Alan.
              • eddiesolo
                • Jul 2013
                • 11193
                Interesting mate, nice start. Will tune in for more wreck fun.
                Si
                  Looks good
                  • Robert1968
                    • Mar 2015
                    • 3596
                    Like what you've done with this so far and like the idea too. I have the exact kit bought cheaply on Evilbay about 2 years ago and thought good things nice ideas ( from Rambo film idea ) but looked at kit when I got it and thought hmmmmm maybe not
                    If you need for spares let me know
                    Robert
                    • Alan 45
                      • Nov 2012
                      • 9833
                      Thanks guys glad to have you on board
                      Robert
                      it doesn't look a bad kit IMO and I think it would look good built properly, I might see if I can get another when funds permit
                        • 22770
                        Looking good Alan watching all the way
                        • john i am
                          • Apr 2012
                          • 4019
                          [ATTACH]108441.IPB[/ATTACH]
                          [ATTACH]108442.IPB[/ATTACH]
                          Bit late now Alan But you could have set the grinder lose on one of these beauties
                          • takeslousyphotos
                            • Apr 2013
                            • 3900
                            That is a great idea Alan .......... I like where you are heading with this. I'll be watching from the side-lines.
                            • monica
                              • Oct 2013
                              • 15169
                              like the sounds of the idea,and very interesting way of going about things,
                              do like the looks of it so far,
