Do not buy it is the worst model you could come possibly come across.
The cockpit was not bad.
But from there on in all that I have come across is a disaster area. Pieces including the fuselage are poor fitting. Nothing and I mean nothing fits snugly one to the other.
Shaved one piece so much I formed a hole in the plastic. Four pods were amazing. Fit two halves together (has the male and female locators) and one side is approx 1mm above the other.
To cap it all it will need (actually it will not it is scrapped) massive sanding then massive filling then it will still not look as it should. On top of that with so much sanding and filling the raised rivet and panel lines will be lost in a large percentage of places. How do you replace them ?
So I am most disappointed I was going to persevere but thought of all the time trying to make this thing look right when I could be building a good model. Just annoyed at the time spent. Unfortunate as it is a good interesting aircraft to build.
So to find another Apache here I go.
