1/18 scale Bölkow Bö-102 Helitrainer scratchbuild model
The Bölkow Bö-102 Helitrainer was an unusual ground-based helicopter training aid that was developed and built by Bölkow of Germany in the late 1950ies. It embodied all essential elements of a conventional helicopter, but was mounted on an articulated gantry to allow a student controlled experience of helicopter systems. Designed to be mounted on a swivelling captive rig the Bölkow Bö-102 Helitrainer allowed trainee pilots to practice procedures such as engine starting, rotor engagement and manipulation of the flight controls. Many of the Bö-102's components, including the single bladed fiberglass main rotor were used in the company's next design, the Bölkow Bö-103.- Type designation: Bö-102B Helitrainer
- Usage: Single seated captive helicopter trainer for basic helicopter training
- Year of construction: 1958
- Manufacturer: Bölkow Entwicklungen KG
- Country: Germany
- Length: 5.68m
- Main rotor area: 34.8m² (374feet²)
- Main rotor diameter: 6.58 m (21ft 8in)
- Powerplant: 1 x Hirth 3-cylinder / 2-stroke 40hp ILO L3X375 piston engine rated at 30kW
- Power: 40shp
- Gross weight: 770kg (1697lb)
- Take off weight without a platform: 325kg
- Crew: 1 student pilot & 1 trainer (on additional seat)
- Speed: Handcuffed on the ground
- Range: Stationary base coach
