Hi all, this is only my second model build so not sure if I'm ready to have you guys riding along, but the critique and/or advice should be good for me so here goes :smiling:
Kit arrived a few days ago, it's a starter set but I don't intend on using the supplied paint
Started by priming up most of the external parts. Since they are going to be yellow I know transparency will be a problem so figured a good white base will help. Not too impressed with the Vallejo Surface Primer just yet though. It sprays and dries ok but it just seems like more of basecoat than a primer. Despite thorough cleaning and a light sanding before applying as per the instructions it still scrapes off easily after a few days, doesn't really seem to grab hold of the substrate like I'm used to. I may try a little plastic adhesion promoter in the future to see if that helps, or try out some of the other primers recommended on here.
Started to throw the interior together. The recommended light grey looked pretty stark and almost like bare plastic, so tried to dirty it up a little on the seats and floor. Needs much more work but I'd rather take it slowly than rush and mess it up.
Added a bit of detail in the radar "cupboard". Probably won't be seen but I reckon it's good practice for the future.
Added a bit of colour to the rear
And started putting the cockpit together
Obviously I have a long way to go but want to start trying to learn some techniques for breaking up the large areas of plain colour, making them look a bit more realistic (still called weathering if it's interior?).
Slowly slowly though, I need to keep telling myself that I don't need to learn everything at once! It'll come in time (hopefully :smiling5
Thanks for looking.
EDIT: Just realised there is a helicopter section! Sorry for putting this in the wrong place
Thanks for looking.
