Revell 1/32 H145M LUH KSK
    • 15679
    Hi all
    John - erecting my big chopper is not easy - where did I put those little blue pills :anguished:
    Scottie - I hope your faith in me is not misplaced.
    Jakko - certainly scraping parts of the inner panels will help. There are a few obvious proud areas.
    Simon - I have seen you cope with worse. I'm a long way from the 'bin it' stage but it will need some studying :smiling2:
    Richard - thanks for such sound advice. I think that the various issues are small in themselves but added together they create bigger problems.
    Peter
    - how you got yours across the finish line and looking so nice is a tribute to your skills. That carbon paper trick sounds good. So glad you mentioned the fit of the canopy. Just checked it and the fit is poor but you're right - slightly widening the top front of the fuselage looks to sort it :thumb2:
    I have spent a couple of hours dry fitting and making small adjustments and things seem to be looking better. I hope I haven't tempted fate with that comment :rolling:
    Thanks again for you comments - encouraging and helpful.
      • 15679
      Hi all
      Well I have fitted the windows which went OK - the fit was actually not bad. I have spent many hours dry fitting, scraping, sanding and then repeating the process. All the while I was frightened I'd wreck the interior or the windows would pop out :thinking: Anyway I got things to a stage where the inner walls and roof would fit on the floor and allow the two fuselage halves to to fit around that. It needed a lot of pressure to get things to join but at least the seams closed up.
      So I glued it and clamped it. Wicked in a load of liquid cement and now it will sit there until tomorrow :tongue-out: Just hope it doesn't all spring apart or I find something inside has come loose.
      Underneath
      At his stage I'm not too bothered about the warped tail end - I'll sort that later. It will come together.
      So fingers crossed for tomorrow. It will be Friday 13th but hey-ho my birthday is the 13th and our house number is 13 so maybe a good omen :thumb2:
        • 22770
        #48
        Nice work Jim.
        • scottie3158
          • 14201
          • Holbeach
          #49
          You like pushing fate lol. Nice work.
          • rtfoe
            • 9074
            #50
            I've got fingers and toes crossed. :smiling6:
              • 15679
              Hi all
              The good wishes and finger crossing seems to have worked :smiling:
              Removed the clamps. The underneath seems solid but I was able to glue to the base as well as along the joins which helped. Filling to do but that's ok. There is a large flat piece which fills the gap and that will add strength.
              The rear top join opened so it was re-glued and clamped. It didn't actually open that much. Because the two top joins will have bits fitted over them I cut some styrene sheet, slathered Contacta on the bits and stuck them over the joints.
              The front join is deliberately slightly open so that the canopy sort of fits :rolling:. Still got that tail to join.
              So onwards and upwards.
              ....... and the windows didn't pop loose
                Nice work getting things to line up as they should — or as close to that as you can apparently get with this kit, anyway
                  Hi Jim nicely done :thumb2:, I was holding my breath then thought better not so crossed eveything I could insert.
                  Keep up the good work.
                  Pete.
                  • stillp
                    • 8091
                    • Pete
                    • Rugby
                    #54
                    Looking good Jim. Watch out for the undercarriage frame on that large flat piece under the fuselage. Mine was distorted and one of the legs broke off when I straightened it.
                    Isn't it a shame about the fit issues, the detail in the kit is lovely.
                    Edit: apart from the seats!
                    • rtfoe
                      • 9074
                      #55
                      Well done Jim, that's the thing with flying things...fitting is crucial so lots of pre-work and testing. There's no mud in the sky or rusting of aluminum to hide bad fit or even battle damage.
                        • 22770
                        #56
                        It looks like you’re getting on top of this one Jim.
                        • Si Benson
                          • 3572
                          #57
                          You had me on the edge of my seat :flushed: Happy to see its playing ball now...your usual methodical approach has paid off yet again sir:thumb2:
                          • JR
                            • May 2015
                            • 18273
                            #58
                            Looking at the struggle you have had and over come I can see why Iv'e only built one plane!
                            Great work Jim.
                            • stillp
                              • 8091
                              • Pete
                              • Rugby
                              #59
                              Yes, you haven't had any fit issues with tanks or tractors have you JR? :tongue-out:
                              • JR
                                • May 2015
                                • 18273
                                #60
                                No Pete no at all, bloody things:smiling2::smiling2::smiling2::loudly-crying::loudly-crying::smiling2::smiling2::smiling4::smiling5:
