Revell 1/32 H145M LUH KSK
Hi all
Jakko - the fit is poor but I think it is as good as possible.
Pete - thanks. So good to have you back posting and modelling.
Peter - you're right. If the fit was better it would be a cracking kit. Thanks for the heads up warning on the base - see update :thumb2:
Richard - your advice to dry fit over and over was very sound, thanks.
Ian - hopefully the worst is over :rolling:
Si - definitely a kit where patience is needed.
John - no fit issues with tanks, hah b****y hahNo tracks though!
JimComment
A bit of progress.
Peter warned me about the base plate. Now when fitting the two fuselage halves I concentrated on getting the best fit on top. The underneath joins were a bit iffy which made the base fit poorly. I glued thin strips of styrene to the base edge to fill the gaps.
Instructions said I needed 30g of weight up near the front. That was quite a lot. I wrapped 30g of lead fishing weights in gaffer tape and stuck it in place with a hot glue gun.
I then fitted the base plate. A bit rough but it will improve with a bit of sanding and filling and it is underneath. I fear I'll sand off some of the rivet detail so, as suggested in the magazine article, I have ordered some Archer rivet decals. Not used them before so I'll see how they work out.
Starting to look like a helicopter :smiling:
Now a question which I hope someone can help with. Instructions 32 and 33 show alternative builds for the rotor arm centre. I can't figure out why they give the choice and which one to use. Apart from using 50A and 50B in place of 50 they appear the same. I wouldn't have the rotors able to spin anyway - for strength I'll just glue it solid.
Thanks for your continued support and banter.
JimComment
Can't help with the instructions Jim, but this really is another one of your textbook ultra clean and tidy builds. Lovely work.Comment
The alternative rotor fittings are so that you can lift off the rotor for storage if you use 50b - takes up less room that way. I had to take quite a lot off to get part 50b to fit, it was clashing with some of the gubbins on top of the fuselage.
PeteComment
Hi Jim, the fuselage looks great and neat. Peter's eplanation is right. Part 50B is deep so that when 50A the longer rod is inserted the rotors won't be wobbly. If you don't have space constraints then part 50 will do the job however it all depends on how part 51 is attached to the engine deck.
32 means you fix and paint in situ unless you glue part 50 to 51 and then only attach/glue rotor assembly at the end. 33 means you have the option to slot and remove the rotors at will.
RichardComment
Hi all
Peter - thanks. I am a bit OCD about tidiness in general. I straighten pictures, keep the car clean and organise my socks in colour groups. I drive the wife to distraction :tongue-out3:
Peter and Richard - thanks for that. I can see it now but before I just couldn't see what the difference was :thumb2: I think I'll go with 33 - I can always glue it later if I want.
Hi all
Mick - thanks. Still battles to be fought :thinking:
John - cheers. I do use glue, honest! Steve will certainly be my go to guy for Archer advice :thumb2:
I have spent the day messing around. First off I looked at the way the rotors were mounted. Thanks to Peter and Richard I realised that there was a way to have the rotor removable. I thought that would be useful for painting as well as future storage. In 33 part 50A is a poorly moulded plastic pin. For strength I replaced it with a brass tube - still to be shortened. I'll epoxy it to the rotor mount and its a nice snug fit into the base.
The engine has a blanking plate in it which stops you seeing inside. Part 49A. Revell want a section cut out to allow space for the rotor base/mount to fit.
Seemed daft to me so I made a new blanking piece to fit slightly further forward so now it doesn't foul the rotor base.
There is a circular intake on each side at the front of the engine. Mostly all you can see is a dark hole.
This is Revell's instruction for altering and fitting them :confounded:
Lord alone knows what that is all about! I shall simply mount the intakes onto the blanking piece, slap on some paint and hey-ho its done. It should look the part at least. I shall take a razor saw to those horn like bits that the intakes were meant to fix to as the get in the way of my blanking plate.
Just messing around :tongue-out:
JimComment
Hi all
A bit more progress - actually quite a good few days :smiling:
Base plate filled and sanded a few times. Filling using Mr S 500 and Perfect Plastic Putty.
The sanding sanded off some of the rivet detail. I replaced the missing decals with Archer decal rivets. First time I've used them and they seem to work well. They are tiny resin bumps on a clear decal film. We'll see what they look like under paint.
Remember this - the front intakes.
The reason Revell tell you to chop bits off is that both parts are for the same side :confounded: Anyway I hacked bits off and fitted them to my blank under the engine cover. They don't really show and matt black will cover a multitude of sins!!
The brass rod shortened and glued into the rotor bit. That then slides nicely into the hole in the engine cover. Makes the rotors removable :thumb2:
Thanks for your support and help - appreciate it :smiling:
JimComment
Hi Jim - not sure where you have stuck parts 60 but the destructions were telling you to fix them to the end of the curved horn thingies
There is a triangle on part 60 that mates with the triangular hole on the end of the horn - or at least it would on one but not on the other after you have to cut it off
So parts 60 should have been at the rear on an angle with the dome facing outwardsComment
