Hasegawa 1/72 Apache
PNVS/TADS — Pilot Night Vision System/Target Acquisition and Detection System (I think, I could have one or two words wrong). PNVS is the small one on top of the nose, TADS is the bigger one underneath; they can turn independently of each other, if you want to pose them other than straight ahead on your model.
Most of the images I've seen seem to have the lower one reversed in a kind of "parked" position. I assume that is to protect the lenses etc when it isn't in use?Comment
Yours is less clinical than the Americans’ beloved wordy description-of-functionAnd reading it back, I realise now I got the D wrong: Designation, not Detection. (My excuse is that I got most of my knowledge on the AH-64 (and the AH-1 Cobra) in the days when you had to get all that kind of information from books, and I dug the name up from my memory this morning
Canopy masking this afternoon. Hasegawa have included the kind of double frame detail the real thing has - the main structural part then an inner Frame or beading that clamps the glass in place. Whilst this is a nice detail it made the masking harder as there was virtually no edge to work to as much of the frame part was thinner than my tape, and completely flush in some places with just a hint of a line where it should be.
[ATTACH]365183[/ATTACH]
[ATTACH]365184[/ATTACH]
Got it all done to a reasonably acceptable level though
[ATTACH]365185[/ATTACH]
The frame was given a coat of the dark grey I'd used for the interior (German Grey lol) in case any was visible when looking into the cockpit, then the whole thing had a decent coat of Mr Surfacer 1000 to show if any more sanding was needed on the seams. On the whole it looks pretty good, but some of my rescribing needs more work
[ATTACH]365186[/ATTACH]
Leaving that to dry overnight I added some colour to these exhaust parts. MrC burnt iron, as per the call out. The instuctions would have you fit these much earlier on, before the engines, but I can just about squeeze them into place. This means I can leave them off until the whole thing is painted to save masking.
[ATTACH]365187[/ATTACH]
[ATTACH]365188[/ATTACH]Comment
The brush guard for the gun was added later as experience showed the gun & ammo feed could get hung up on stuff like tree limbs & wires in the heat of action. I see they modeled it as early production as shoulder armor plates for the crew are missing also. Shaping up nicely. Can't wait to see the finishes. PaulEComment
Busy day so didn't get much shed time, but progress is progress.
I finished the final sanding and had another attempt at rescribing the panel lines. Then a full coat of black Mr Surfacer, which went on lovely and smooth, then some pre-shading with the white version which didn't.
I'm not sure if it's just white being white or whether the cold has affected it, but spraying was very stop/start and splattery due to tiny lumps in the primer which blocked the nozzle momentarily. I'll make sure I give it a good filter next time as it made the job hard work, not enjoyable, and the results aren't quite what I wanted. Should still look good with the topcoat on though
[ATTACH]365314[/ATTACH]
That's this at a standstill now until I get some more paint. I still haven't settled on what paint line to fully invest in so keeping stocks low. I really must try MRP as it gets rave reviews everywhere, but since it's not the most widely available line I'll have a go with the Tamiya lacquers first. Not that I've anything against Mr Color as I really like it, but there might be something out there that's even better :smiling3:Comment
Thanks Joe.
Got some colour on this morning. I decided to go with the Model Air I had rather than waiting for something else to arrive. As ever I've struggled to pick up the pre shading on camera but it's probably my best effort yet. I'm not a fan of the massive contrast seen in some models anyway, but each to their own :smiling3:
[ATTACH]365555[/ATTACH]
[ATTACH]365556[/ATTACH]
[ATTACH]365557[/ATTACH]Comment
Thanks Jim, the rescribing was quite successful in places in places so I'm happy with that. Not so much in other areas where I now have "tram lines" but there's more good than bad so I'll take it as a win lol
Cheers Tony. I need to pay more mind to my stirring and filtering. I wouldn't dream of skimping on those in the day job so ought to bring that home with me. I filtered the Model Air olive drab for this and was amazed at how many lumps were left behind, and the paint sprayed beautifully afterwards!Comment
