Minihobby Mil Mi24 Hind F in 1/48 scale
Been quietly doing things on this one . The crew cabin is done , the bench is fitted with four sets of etched belts added from the spares box . The LLTV , FLIR sensor under the nose was a bit simplified and not representative of the Hind F. The later version as fitted to the F has a different retraction system for the sensor armoured covers with twin springs and linkages for the two per side covers. A bit of plastic card and some springs made from guitar string and it’s looking something like. A bulge was also added on the side of the housing. Similarly the teardrop shaped missile sensor on the other side of the nose benefitted from a bit of jazzing up too .
The cockpit is taking the most time with this build , as I’m having to make most of it from scratch and it’s a complicated pit. The main switch panels have been added with plastic card / rod / strip and wine foil ( embossed with one of those riveters everyone seems to have but doesn’t use) these just needing a careful paint up and possibly some decals here and there. Some heater pipes / cables have been added to the front cockpit . The front IP is done ,the pilots still needs painting up
Theres still a lot of bits to add like the gunsights / weapon aiming sights and the canopy has its fair share of stuff dangling from the inside too . cheersComment
Cheers colin , the cockpit is so prominent and visible through the large canopies i couldnt leave it as supplied , good thing is for the next mi24 i’m doing , ive got myself a resin cockpit !!Comment
Slowly moving on with the cockpit, the various switch panels have been painted black and the surrounds in the lurid blue green . Next they need to have the details added with a combination of careful painting and random decals from the spares box. I’ve also been working on the WSOs cockpit . The kit supplies a very basic representation of the mi 24 D equipment but the F is a bit different . I’ve already covered scratching the instrument panel and now I’m sorting the various weapon aiming instruments .The kit supplied items are basic to say the least so the FLIR /LLTV scope has been thinned down and spruced up with bits of plastic rod and a bit of aluminium tube for the eyepiece. The bit of equipment beside this isn't supplied so I’ve had to scratch this from bits in the spares box ( a sprue of spare aerials from the Eduard MiG 21 came in very handy!)Comment
Slowly getting there with the painting , but still a bit of tidying up to do . Got the sighting rigs finished ready to go on and finished the main instrument panels . Once all this is done I can get the seats and cyclic sticks/ collective levers in and then maybe think about getting the fuselage togetherComment
After a lot of touching up and repainting I’m happy enough with the pit. The instrument panels , control sticks and seats have now been fitted and also the quilted padding behind the WSOs seat, which was made from wine foil ,scored with a ballpoint. The pit and the troop compartment were bit sandwiched between the fuselage halves along with the engines and rotor base.Comment
