Minihobby Mil Mi24 Hind F in 1/48 scale
Got the undersides painted yesterday , ready for masking now and the tricky top camo. The top Is a sand background with squiggly green patches , havenโt decided if its going to be easier to do the green overall first then mask off the patches or do the sand first and hand paint the green . It doesnโt really matter either way as the hind used masks in real life so the camo is all hard edged .Comment
Top work so far Tony!!! Just had a catch up and very impressive stuff here...Come on, pull the masking and let's see what you got there Sir!!!
Bleib Gesund
AllenLife's to short to be a sheep...Comment
Masked up and got the yellow on ( Tamiya xf60) . The masks were cut from some extra wide 40 mm tape which I stuck onto some adhesive label backing paper I saved . This means I can mark it with a pencil , cut it out with scissors and then peel it off and apply to the model. Some tricky shapes but eventually I got it all done . I think there may be some touching up but hopefully not too much , I sprayed the XF 60 quite dry so as to minimise the chance of any creeping under the tape edges. Weโll have to see tomorrow . Cheers tonyComment
Cracking result Mucker!
Excellent masking, but I tell thee wot, owd lad, I'm reet glad I don't have to mask my stuff for painting. It would drive me insanitary!
Sel O'TaypComment
Its now had a coat of klear and the decals applied. The exhausts had a big gap round the edge which on the real thing is covered by a metal ring so a couple of off centre rings were cut from tamiya tape and sprayed silver . These were stuck on and will get sealed in .Next step is a matt coat then I can see about toning the paintwork down a bit . The paint on most Hinds faded quite a bit so im going to give it a misting with some thinned beige . Meantime ive been painting the rotor head and blades and tail rotors , and getting the weapons painted.Comment
