Minihobby Mil Mi24 Hind F in 1/48 scale
    • 22771
    #76
    Looking very good Tony.
    • Fernando N
      • 2448
      #77
      Fantastic work Tony, love how you tackled the canopy issue and adding all the detail to the office
      Neat paintwork too:thumb2:
      • yak face
        • Jun 2009
        • 13844
        • Tony
        #78
        Cheers Fernando , I’m curious to see whether it comes out ok , I’ll not know till I take off the masking :anguished:
        • yak face
          • Jun 2009
          • 13844
          • Tony
          #79
          It’s now had a misting with very thin desert yellow to tone the camo down a bit . I’ve fitted the tail rotor and tail planes too a given it a bit of exhaust staining . I can take off the masks tomorrow and we’ll see if the canopy fix worked .Its all little bits now but these take the most time, Click image for larger version
ID:	1124377Click image for larger version
ID:	1124378Click image for larger version
          • yak face
            • Jun 2009
            • 13844
            • Tony
            #80
            Took off the masking today and thankfully it doesn't look too bad . I took off the pilots door as this had only been temporarily attached and the areas around both the doors need a bit of touching up and neatening . The canopies will also be getting a tidy up round the frame edges . The main rotors have now been finished , black underneath , green on top , yellow tip warnings on the undersides and bare metal leading edge de icing strips .Click image for larger version
ID:	1124491Click image for larger version
ID:	1124492Click image for larger version
ID:	1124493Click image for larger version
ID:	1124494Click image for larger version
              • 22771
              #81
              Looking good Tony.
              • HAWKERHUNTER
                • Feb 2012
                • 1615
                • Steve
                • Halifax, West Yorks.
                #82
                Just latched onto this build Tony. Looking great
                • yak face
                  • Jun 2009
                  • 13844
                  • Tony
                  #83
                  Bit more progress on the hind . Ive got the wheels on and they’re just setting , so while I can’t do anything with the main airframe I started on the pilots door . The kit supplied door is just a thin featureless piece , although the kit does supply a latch handle and the gas strut . The door should be quite chunky with a lip round the edge , two storage pockets and a demisting tube running under the window . See pics . So it had some plastic strip round the edges , a piece of scrap for the half door and some wine foil bent to shape for the pockets. I used the kit latch handle but cut it down a bit and the bent wire for the demister bar will be fitted after I’ve painted the door . Click image for larger version
ID:	1125014Click image for larger version
ID:	1125015Click image for larger version
ID:	1125016Click image for larger version
ID:	1125017Click image for larger version
ID:	1125018Click image for larger version
                  • yak face
                    • Jun 2009
                    • 13844
                    • Tony
                    #84
                    Bit of paint on the door , matt black for the door and gloss for the elasticated pockets - this looks too shiny so will be knocked back a bit. The door on the Hind F has a mirror attached ( I presume for the pilot to check his make up and hair ?) so it was out with my trusty nail art gems again , the rear face of these is a mirror like silver , a rectangular one being selected and mounted on a brass wire arm . Theres just the demister bar to fit and paint to touch up then the doors ready for fitting last off . Click image for larger version
ID:	1125220Click image for larger version
ID:	1125221Click image for larger version
                    • yak face
                      • Jun 2009
                      • 13844
                      • Tony
                      #85
                      The door has now had the demister bar added and pockets matted down a bit so is done . I’ve also been addressing the stores . No Hind looks properly dressed unless it’s packing some heat so the two different types of unguided rocket launchers were selected . The pylons had the home made sway braces fixed to the rear mounting point before the stores were fitted . The at6 shturm anti tank missiles were chosen for the stores position on the end of the stub wings and were painted in a brown orange colour . Looking at pics of these on the web shows them to have eight black lines round them so how to sort this ?
                      Quick tip time , most decal sheets have a thin black outline running all round the sheet, the trick is to look and see if it’s also got a carrier film over it , if it has save it in the spare decal box , it comes in handy for things like this or wing walkways . The one I used was from an Airfix 1/48 Sepecat Jaguar , Airfix seem to be a good source of these black lines . Anyhoo the 32 little decal strips were put on and they look better for it . Click image for larger version
ID:	1125434Click image for larger version
ID:	1125435Click image for larger version
ID:	1125436Click image for larger version
ID:	1125437Click image for larger version
ID:	1125438Click image for larger version
ID:	1125439Click image for larger version
ID:	1125440Click image for larger version
                      • spanner570
                        • 15430
                        #86
                        Some neat work there, old lad.
                        • yak face
                          • Jun 2009
                          • 13844
                          • Tony
                          #87
                          Cheers mucker , it’s got to the stage now where it’s all just fiddly little bits and the more bits I stick on the more difficult it is to handle without breaking em off again! I’ve already had to re attach one of the main rotors and one of the tail rotors with brass pins !
                          • flyjoe180
                            • Jan 2012
                            • 12433
                            • Joe
                            • Earth
                            #88
                            Looking great Tony, your usual hig hstandard of scratching brings it to life
                            • yak face
                              • Jun 2009
                              • 13844
                              • Tony
                              #89
                              Well after a final push I’m calling this done . The last few furlongs have been a bit of a bugger , all tiny bits that needed adding and each one making it harder and harder to handle without breaking bits off.The WSOs cockpit has been finished off by gluing in the cooling fan and the sighting rig I made earlier and the cockpit doors have been stuck on with demister bars being added to both doors from fuse wire . The prominent pitot on the front of the canopy had to be sorted as the kit one only had two vertical vanes whereas the actual one has four - two vertical and two horizontal . Luckily the kit provides two , one with a blade aerial and one with the odd rods IFF aerials so I just cut off the front of the spare one and stuck it onto the one I’m using .Other last minute additions are the windscreen wipers, cabin doors , cannon and louvred cover , aerial wires ,and the nav lights on the wings and fuselage top -once again the nail art gems coming out!. I’m happy with how the canopy turned out , considering how fubar it was at the beginning .
ID:	1126046Click image for larger version
                              To sum this kit up ,it’s a bit of a mixed bag really . Its obviously a copy of the Monogram kit but with a few alterations to make the F version . Some details are great but others are simplified or non existent .The cockpit is poor to say the least and is for the D version only so has to be addressed if you want a F. The sloping exhausts are for an early D - on the F they were straight , I decided to overlook this as it was too much hassle to scratch new ones ! If you want to build a D version though there is hope . A resin replacement D version cockpit is available from aires , which I have bought for the next one I’m doing , which will be a Czech Air Force machine and this time I’m doing it in flight so all doors closed ,pilots in and it should be an easier build .
                              Im just off now to take some more pics for a completed thread , thanks for anyone who’s still following ( I know it’s been a drag !) cheers tony
                                • 22771
                                #90
                                Great work throughout Tony, it’s been a pleasure to watch coming together. Looking forward to seeing the completed photos.
