papa 695s 1/35 MiniArt FL 282 V6 Kolibri
    • 22771
    #31
    Got most of the framework built, painted and fitted. Also put the PE onto the sides.
ID:	1119187Click image for larger version
ID:	1119188Click image for larger version
ID:	1119189Click image for larger version
ID:	1119190Click image for larger version
    I’ve seen on some builds online that this is a tail sitter. So I’ve put some lead into the IP, and I’ll put some onto part C20 on the inside .
ID:	1119192Click image for larger version
ID:	1119193Click image for larger version
ID:	1119194Click image for larger version
ID:	1119195Click image for larger version
    • yak face
      • Jun 2009
      • 13855
      • Tony
      #32
      Cracking work Ian , lots of fiddly struts and stuff but a fascinating build . I never realised there was a small propeller on the front of the engine, obviously to provide cooling for the radial engine , and I also never saw that the rotor system is the twin intermeshing type , used later by Kaman on the Huskie . Cheers tony
      • scottie3158
        • 14221
        • Holbeach
        #33
        Ian,
        Nice work so far all looks very good.
          • 22771
          #34
          Got some paint on this now.
ID:	1119419Click image for larger version
ID:	1119420Click image for larger version
ID:	1119421Click image for larger version
ID:	1119422Click image for larger version
ID:	1119423Click image for larger version
ID:	1119424Click image for larger version
ID:	1119425Click image for larger version
ID:	1119426Click image for larger version
ID:	1119427Click image for larger version
ID:	1119428Click image for larger version
ID:	1119429Click image for larger version
ID:	1119430Click image for larger version
            • 22771
            #35
            Got the decals on.
            [ATTACH]379170[/ATTACH][ATTACH]379172[/ATTACH][ATTACH]379173[/ATTACH][ATTACH]379174[/ATTACH][ATTACH]379175[/ATTACH]
            • colin m
              • 8770
              • Colin
              • Stafford, UK
              #36
              Very, very interesting, and probably the strangest build of 2020 - I know it's only April, but I don't think it will be beat.
              • Neil Merryweather
                • Dec 2018
                • 5199
                • London
                #37
                that's very nice indeeed .do you have a pilot?
                • NickT
                  • Apr 2019
                  • 194
                  #38
                  Superb build and paintwork - I think its brilliant.
                    • 22771
                    #39
                    No you don’t get one, and being 1/35 there’s not many seated pilots around
                    • colin m
                      • 8770
                      • Colin
                      • Stafford, UK
                      #40
                      Does anyone know why helicopter type things tend to be 1:35 scale ?
                      • Neil Merryweather
                        • Dec 2018
                        • 5199
                        • London
                        #41
                        I have wondered this myself. I think must be because they are associated with the army, and therefore tanks and soldier figures.
                        Also the Horsa glider by Bronco is 1/35, as are all the paras, but what if you wanted a Dakota to tow it? It would have to be 1/32 scale. I quite like the idea of a model of bunch of paras jumping out of a Dakota, but I'd need to convert 1/32 scale figures.
                        But can you get an army cooperation plane like a Piper Cub or Fiesler Storch in 1/35?
                        not that I know of. it's just weird!
                        • Gern
                          • 9226
                          #42
                          Tristar used to do a very nice Storch in 1/35 (I'm sure I've seen it re-boxed by someone else too) and Bronco do a Piper Cub in 1/35.
                          • Gern
                            • 9226
                            #43
                            Ian, that looks very nice. Not at all sure I'd trust my life to such a weird contraption though!
                            • Steven000
                              • Aug 2018
                              • 2830
                              • Steven
                              • Belgium
                              #44
                              Very nice progress Ian! :thumb2:
                              Steven
                                My guess is that it’s twofold. The main one is that these 1:35 scale helicopter kits, when they started coming out in the early/mid 90s,¹ were aimed at AFV modellers rather than aircraft modellers. Military helicopters are, after all, much more an asset for ground forces than for air forces (even if they’re actually operated by the air force in many countries), and if you’ve got a showcase full of 1:35 scale tanks and trucks, a 1:32 scale helicopter will be out of place just a little.
                                Another reason is probably so the helicopter fits with commonly available military figures and accessories: if you’re building a UH-1 in Vietnam livery, chances are you’ll want a bunch of troops in the back, and those are hard to come by in 1:32 but easy in 1:35. Yes, the difference is obvious if you try to mix them: in the back of a Revell 1:32 scale UH-1, a group of 1:35 scale troops is likely to look a bit on the small side.
                                ¹ Heller already made 1:35 scale helicopters in the 1970s, mainly Super Frelons, but the scale only really became relatively popular when Dragon released some kits in the 90s.
