Zvezda 1/48 Mil-24N Hind
One of my favourite Russian helicopters. I will look forwards to this one.
Hide the super glue !Comment
I have spent the morning on the cockpit interior.
First impressions are overall good.
The plastic is similar to ICM, perhaps a little softer, definitely a better quality than Airfix. The parts are crisply moulded. For the most part the fit is good but I have had some issues with vague fitting which is only an problem in respect of the engine section in the picture below. The two slanting rods should fit the small posts in the corners. I really donโt know how this went wrong, it all looks right as to how these parts were fitted together, but it does not matter as I intend to โbutton upโ so none of this will be seen. I will be able to hack it around if need be. It would be a problem if you wanted the hatches all opened up though. There are some anomalies with the instructions not matching the parts but nothing major, mostly things like locator pins missing on the parts that appear on the instructions or different shaped pins.
Here are the interior sub assemblies so far completed. At this point I need to paint before proceeding further with them. There is no raised instrument detail, relying only on kit decals for this. That is fine with me, it saves sanding it off, the Quinta set will deal with this raising the interior to the next level!
I have sprayed some colour into the cockpit and rear compartment plus some black.
I do like that strange turquoise colour the Russians used in their cockpits. The MRP version is a good match for the Quinta set.
I decided not to black base the internal areas so any shading will be down to washes.
Technically I should have used a slightly different light grey on the transmission block but, to be honest, little, if anything will be glimpsed through the small windows I donโt think it will make any difference.
I will be hand painting some detail next before applying some Quinta details.
On to the 3D Decals. I donโt think calling them โdecalsโ does them any favours. I got into a discussion on social media about these and one person could not believe that โdecalsโ could possibly look better than etch. He was fixated on the word decal and imagined them as some kind of cleverly printed, well, decals. I am not sure that I convinced him that they are not actually decals in the accepted sense.
These are 3D printed flexible plastic material carried, for convenience, on paper from which they are released by soaking in warm water.
Here are the parts for the instrument panels released from their backing. You would not get away with this using decalsโฆ..
I attach these parts using Gator Grip but any white pva type glue will do. You could use c.a. but you do need time to get the part into position.
Here is one of the side walls done
now I got a bit concerned because looking at the above from the other sideโฆ
The 3D Decal extends beyond the side wall. I did a test using the outer cockpit panel and found that there is no need to worry it all fits in perfectly.
More done
I particularly like the seat belts as they can be set to hang more naturally than etch and do not drive you mad like the fabric ones. These are the best seatbelt solution available. Incidentally, while this set is a Quinta Studio one a lot of other companies are producing them like Kits World and Red Fox.
I
I will do a light brown wash over the belts to give them a used look.
To summarise, 3D Decals provide a better looking result than etch while being a lot easier to use.
Incidentally, I made an ordering mistake with these 3D Decals and have a spare set. I donโt expect to build another Hind so if anyone is planning to build one of these kits then pm me and I will send you the spare set, no charge.Comment
I really have forged ahead today. I donโt think that I have ever progressed a build this quickly before.
I finished attaching the main fuselage sides
Then the nose sections and a few other fuselage areas. The fit is really excellent specially given the complex shapes.
I have also been pulling together some other sub assemblies.
a close up of the cockpit
All I all this is turning into a really good build.Comment
