Rick’s Airfix Sea King HC4, 1/72, Operation Mikado, Falklands war
  • rickoshea52
    • Dec 2011
    • 4076
    • Rick
    I’m building this for a GB at my local model club. It’s well under way already I just haven’t been taking photos of the build.
    [ATTACH]447702[/ATTACH]
    Operation Mikado was a botched mission to insert special forces into mainland Argentina.
    It’s mostly assembled and received a coat of green paint.
    The kit needs a bit of back dating from the kit version. A lot of the lumps and bumps aren’t needed so some filing and smoothing is required. A large blister fairing behind the cargo door was found in the spares box.
    Some minor scribing was added to the engine cowlings.
    The tail fold bulkheads are barren so I added wire here for the electrical harnesses, two slices from plastic rod for the driveshaft DCC and a sliver of plasticard for the tail rotor pitch control link. Drilled lightening holes on the fuselage side bulkhead and trimmed on the tail pylon side.
    Photos to illustrate.
    [ATTACH]447703[/ATTACH][ATTACH]447704[/ATTACH][ATTACH]447705[/ATTACH][ATTACH]447706[/ATTACH]
  • rickoshea52
    • Dec 2011
    • 4076
    • Rick
    Got some paint on the tail fold. Weathering and a wash next.
    [ATTACH]447766[/ATTACH]
    The blister fairing has been masked and received a coat of white. When dry some more masking and light grey.
    [ATTACH]447767[/ATTACH][ATTACH]447768[/ATTACH]
    • Tworrs
      • Jan 2022
      • 1980
      • Garry
      • New Zealand
      Great detail Rick.
      • JR
        • May 2015
        • 18273
        Great work Rick , love the wiring , adds that something to the build .
        • Jon Heptonstall
          • 1704
          Great stuff.
          Have you read Special Forces Pilot by Richard Hutchings? He was the guy who ended up flying into Argentina with his SAS passengers and e&eing to Chile.
          Jon
          • Geoffers
            • Jan 2017
            • 1700
            • Geoff
            Nice scratch building Rick, looking forward to seeing a bit more of your build.
            Geoff.
            • rickoshea52
              • Dec 2011
              • 4076
              • Rick
              Originally posted by Jon Heptonstall
              Great stuff.
              Jon
              No, I haven’t read that book. Maybe I should have before I started because I’ve taken a bit of modellers licence with my build.
              I’ve made the assumption that this cab would have been stripped of as much excess bits as possible to extend its range. That’s why I have avoided fitting the SACRU under slung load gear and rescue winch. I did consider not fitting the cabin troops sears but decided even tough guy SAS types need a seat for their hairy 4r$€$ so left them in.
              I filled the fuselage holes for the winch and added tiny bits of plasticard to replicate the attachment points.
              • rickoshea52
                • Dec 2011
                • 4076
                • Rick
                I’ve completed the painting and varnishing of the fuselage and attaching parts. Decals next.
                • rickoshea52
                  • Dec 2011
                  • 4076
                  • Rick
                  Here’s some of the work I’ve done to back date the kit version to a 1982 cab. A lot of the modern defensive aids needed to be removed or omitted from the build.
                  • rickoshea52
                    • Dec 2011
                    • 4076
                    • Rick
                    My next retrofit conundrum is the main rotors. Airfix’s kit provide the modern composite blades in either spread or folded configuration with some nice detail and realistic droop; these are no good for a Falklands cab.
                    In 1982 Sea Kings were fitted with metal blades which have a different shape. No problem - I have some spare blades from an old tool Airfix Sea King that are right shape.
                    After a close look maybe not. Plan B is to nick the rotors from a Cyber Hobby AEW kit. Much less clean up to do but still some faffing with assembling them in the folded position I want.
                    • rickoshea52
                      • Dec 2011
                      • 4076
                      • Rick
                      This photo shows the winch fittings made from plasticard for the frame attachment points, brass wire for the grab rail and blanked off hydraulic and electrical unions - Sea King winches are hydraulically powered.
                      • Jon Heptonstall
                        • 1704
                        Give us your address Rick and I'll send you the book.
                        Best quote: On touching down and deciding to abort.
                        " It's Chile"
                        " It's f*****g freezing mate"
                        Jon.
                        • Ancientmariner
                          • Feb 2018
                          • 859
                          Looking fantastic Tim!
                          • rickoshea52
                            • Dec 2011
                            • 4076
                            • Rick
                            Who’s Tim?
                            • Ancientmariner
                              • Feb 2018
                              • 859
                              Who’s Tim?
                              Loosing my marbles I'm afraid Rick :rolling:
