Steve, get yourself well.
First project: Sea King HAR3
Yeah,
Completely concur with the Guys Steve.....
Get back to proper health ....... we`ll all still be here upon your return:thumb2:
All the very best to you mate!
AndyComment
Personally, I would leave them as they are, The only bit visible when the fuselage is together is a tiny section of rail through the window. Don’t forget to paint it!On the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
Just finished: Airfix 1/48 Stuka & Airfix 1/72 Sea King HC4.Comment
Progress so far, main paint job done. A few colour changes to take care of.
Had trouble with getting both fuselages to fit properly, came very close to binning it. Managed to get a good fit in the end.
As said at the start, first model for 50+ years. Using stuff that I’ve never used before like liquid mask, Eduard precut masking, Clear paint on canopy, Decalfix among a few. Got on well with most, but have major problems cleaning some windows after the Eduard masking. Got on well with the rest though.
Thinking about weathering now, will need advice on that.
Thanks for all the advice so far, more welcome.
I fairly pleased with what I’ve done so far, made some mistakes, but with the dose of Covid mid assembly not helping, it looks fairly good.
Hopefully will finish by the weekend.
Thanks again guys.
HI Steve looking very good an yes i will proberly have the same problem with jioning the fusalarge havrfles an when i treid it without pressing hard it was a job to line them up so i suppose i will have to do it a bit at a time but yours looks very good indeed an im glad you dint bin it but what problems did you have with the Eduard masking. as i have some as well ? to fit on my seaking
chrisbComment
chrisb
Now trying thinners or soaking it as don’t want to scratch it.Comment
Firstly the cut was done correctly or deep enough. Got that sorted ok, put on undercoat and a couple of top coats , let it try for a couple of days. Come to demask, fluid mask ok, Eduard masks some were ok but the 3 front canopy windows were terrible. Looks like the sticky part of the mask has stayed on.
ATB chris bComment
