Oh dear it's a 1/72 Bristol Beveldere
Thanks Tim, I've gone a little overboard on this I think. Meant to be a simple conversion. I could have left the cockpit well alone but having the door slide open meant that a bit of detail had to be added. Airfix doesn't give a cyclic, only a stub, no collective, not even a dashboard/IP. I just hope the rudder pedals can be seen from the large chin window.
Working on the cyclics and collectives next.
WabbleComment
[ATTACH=CONFIG]n1208046[/ATTACH]
Wabble:smiling2: :thumb2:
Thank you Jim.
You too Scottie.
Today, thickening and extending the prop shafts and a length of wire inserted into pre-drilled holes for added strength so they fit snuggly into the tube.
You've gotta guess where these are going to...
WabbleComment
Hi guys, I sanded the top and scribed the reverse side of the prop. Unfortunately the release pin marks are on this side and will need filling in.
And just look at the wheels supplied two of which have gaping holes from bad molding process...flash everywhere.
I will either fill with a cut plastic disk or two part putty whichever is the easiest. The holes for the axles are humongous. It's still a good kit...the only kit. :smiling6:
WabbleComment
Hi guys, I sanded the top and scribed the reverse side of the prop. [COLOR=rgb(226, 80, 65)](Rotors).[/COLOR]Unfortunately the release pin marks are on this side and will need filling in.
[ATTACH=CONFIG]n1208181[/ATTACH]
[ATTACH=CONFIG]n1208182[/ATTACH]
Wabble:smiling2: :smiling2: :smiling2:
(We'll make an air fitter of you yet Richard)Comment
What gets me is how complex the unmodified rotor heads are in the first place
Have to say the wheels are a dead loss, though I think we'll be impressed with your coming improvements!Comment
I've taped the rotors onto the insides of a sauce pan and poured hot water in to get the sag of the rotors. Turned out just a little over bent so am bending them back slightly without breaking them. Pictures later.
WabbleComment
Hi there guys,
The Belvedere is keeping my mind off Jen Jen.
Latest fitting to see if the sag is enough...
The box top picture shows short stubby rotors but these are long and spindly. Starting to turn from an ugly duckling to a swan. I quite like how it looks although it resembles a dachshund or longhouse.
WabbleComment
