Oh dear it's a 1/72 Bristol Beveldere
  • scottie3158
    • 14201
    • Holbeach
    #166
    Wabble,
    The props look spot on.
      • 15687
      Originally posted by rtfoe
      Starting to turn from an ugly duckling to a swan.
      Most definitely thanks to all the work you're putting in.
      • Waspie
        • Mar 2023
        • 3488
        • Doug
        • Fraggle Rock
        #168
        You have the 'droop' on the rotors just about bang on there. Honestly if you see the rotor blades being made it would shock you. Very agricultural. What you can't see in most helicopters rotor is they actually impart a very slight twist in the blade. (This is all to do with the amount of lift produced over the length of the blade in line with the rotating speed. (The inside, next to the rotor head, will not be as fast as the rotor tips!!). To achieve this Westlands used a jig to hold the rotor and then with a scaffold pole, turn the leading edge spar to get the required angle. Only a degree or so, nothing you would see with the naked eye unless with it off the helicopter!!!
        Looking very much like the rotorcraft it really was and not the image on the box. Superb jiggery pokery.
        • rtfoe
          • 9082
          #169
          Originally posted by Andy T
          Sorry for not popping in much Richard but I've been following the excellent work here from a distance.
          No worries Andy, noticed your likes. Having you along to observe and follow is great.
          Wabble,
          Thank you Scottie.
          The reason is I'm having fun Jim.
          Thanks Doug, initially the droop was overdone and I had to tease them back. On doing so the rotors has a slight twist.
          Here's the rotors with a coat of black and grey base. I've yet to cover the attachment points of the left rotor...
          And I've worked on the IP, the Vallejo silver on the pedals doesn't seem to work. Will repaint with Mr Color Silver.
          That's it for today...just recovered from a sinus attack.
          Wabble
          • rtfoe
            • 9082
            #170
            Just added the clips for the mesh that attaches to the fuselage and resized the square bulge that replaces the antennae.
ID:	1208404Click image for larger version
            Wabble
            • Mickc1440
              • 4775
              #171
              Just keeps getting better, lovely work
                • 22770
                #172
                Some cracking work Richard, looking forward to the next instalment.
                • rtfoe
                  • 9082
                  #173
                  Thanks Mick and Ian, here's the next instalment...
                  The square bulge got some putty added and will be sanded smooth...
                  ...so did the chin area joint under the cockpit and the second part of the belly bulge as well...
ID:	1208418Click image for larger version
                  ...then I filled the hole in the wheels shown front and back. I'll be strengthening the back with a sliced disc from a thick rod. If I can I will add spoke detail to the hub.
                  Wabble
                  • Fernando N
                    • 2448
                    #174
                    Taking shape nicely Richard :thumb2:
                    • scottie3158
                      • 14201
                      • Holbeach
                      #175
                      Wabble,
                      Outstanding work mate your eye for detail is superb.
                      • Airborne01
                        • Mar 2021
                        • 3968
                        • Steve
                        • Essex
                        #176
                        Don't forget the tyre valves! Only joking Wabble - looking superb already!
                        • rtfoe
                          • 9082
                          #177
                          Thanks Fernando, good to hear from you.
                          Wabble,
                          Thanks Scottie, I'm just winging it...can't bling as much as you can.
                          Look carefully Doug and you might see it...just kidding too. I'd be crazy to add that. :smiling6: Thanks.
                          Made some progress but no pix...had to rush back from the LHS. They're canopy and cargo doors, sanding of puttied areas and the front rotor conduit above the canopy.
                          Wabble
                          • rtfoe
                            • 9082
                            #178
                            Pix of progress...
                            Used a vacformed bubble wrap cut larger than the window size for the curved window attaching it with putty, masked and sanded. Cockpit window cut out and will add strips of plastic for the sliding bracket and windshield cover. The Belvedere had only a sliding window on one side of the canopy as the other side has a bulge aft of the window blocking any chance of a slide opening. I'm guessing it hinged up. Then there's the piece for the extended rotor conduit. Here's a closer look from the side...
                            Wabble
                            • Waspie
                              • Mar 2023
                              • 3488
                              • Doug
                              • Fraggle Rock
                              #179
                              [COLOR=rgb(226, 80, 65)]Look carefully Doug and you might see it...just kidding too. I'd be crazy to add that. :smiling6: Thanks.[/COLOR]
                              Wabble
                              Not me this time Richard!!!! :smiling2:
                              • rtfoe
                                • 9082
                                #180
                                :smiling6: Must have been the Thosai I was having for supper...the reply was meant for Steve, my apologies Doug.
                                Wabble
