Oh dear it's a 1/72 Bristol Beveldere
  • Waspie
    • Mar 2023
    • 3488
    • Doug
    • Fraggle Rock
    #211
    Love the cockpit. Brilliant.
    • rtfoe
      • 9082
      #212
      Originally posted by minitnkr
      I use SWMBO's fingernail foam sanding block for clear parts. It has shape, smooth, buff & shine grades & works great.
      I use two grades of sand paper, Auto rubbing compound and Tamiya polishing compound with a final dip of Future, Paul.
      Originally posted by Jim R
      That cockpit really looks the part. Your additions make all the difference.
      Thanks Jim, sorry I forgot to take photos of the process but to let you know it will still looked slightly cloudy before the dip and you'll see the miracle happen...just look at the result.
      People always make the mistake of airbrushing Future over the clear canopy which blurrs the whole clear part.
      Thanks Doug, I like it too.
      Wabble
        • 15689
        That canopy is brilliant :smiling2: :smiling2:
          • 22770
          #214
          Great work with the canopy Richard, it doesn't look like the same part. Pity about the seam line though.
          • rtfoe
            • 9082
            #215
            Thank you Jim.
            Sadly the seam line stays as the glue joint cannot be get at. Anyway it will only show in the bottom of the canopy as the rest will be covered by the painted frame
            Here it is test fitted again...
            The dash board IP and overhead console has been attached.
ID:	1208787Click image for larger version
            Wabble
              • 18903
              Miraculous work on that canopy Richard. Superb!
                • 22770
                #217
                Once again, outstanding work Richard.
                • Mickc1440
                  • 4775
                  #218
                  I'm complaining about issues in 1/24 scale and you're doing this great work in tiny scale
                    • 15689
                    Ditto
                    • Waspie
                      • Mar 2023
                      • 3488
                      • Doug
                      • Fraggle Rock
                      #220
                      Every bit of this build has just been outstanding. The improved cockpit - just another level entirely.
                      • Steve-the-Duck
                        • Jul 2020
                        • 1731
                        • Chris
                        • Medway Towns
                        #221
                        Never noticed before, but there's no access from the cabin to the cockpit. Hmm, so only intercom to warn the pilots you're on fire!
                        • Waspie
                          • Mar 2023
                          • 3488
                          • Doug
                          • Fraggle Rock
                          #222
                          That’s not necessarily a bad thing!!!
                          • rtfoe
                            • 9082
                            #223
                            Thanks Tim, much obliged.
                            Thanks again Ian.
                            Mick, you'd be surprised how much you can get away with in smaller scale.
                            Ditto
                            Ditto answer too Jim.:smiling3:
                            Thank you Doug.
                            There is an access through the back of the co-pilots panel. Didn't bother to drill that out. That's why there's a bulge on the left for the passage way past the engine.
                            Ya to keep your mind on flying and not panic.:tears-of-joy:
                            Wabble
                            • David Lovell
                              • 2186
                              #224
                              Sorry Richard ,I have been watching from a far literally (see what I did there)but the chaps always express it all any way ,with long builds like this I like to look at the pictures of the finished product then read the whole thing backwards for me anyway you get a much better understanding of what went into the final photos ,l know even the other halfs finally beginning to think I'm a bit damaged. Dave
                              • Waspie
                                • Mar 2023
                                • 3488
                                • Doug
                                • Fraggle Rock
                                #225
                                Hey Richard, have you seen this Video of the helicopter?
                                Westland Promo Video
