Oh dear it's a 1/72 Bristol Beveldere
  • rtfoe
    • 9084
    #31
    Originally posted by JayCee
    Hi Richard. I was in Aden 64 to 67, so basically the whole of the "Emergency". I was not in the forces though. I was in a branch of the Diplomatic Service.
    John.
    Were you evacuated by Aircraft carrier at the later stage of leaving Aden?
    Wabble
    • Waspie
      • Mar 2023
      • 3488
      • Doug
      • Fraggle Rock
      #32
      Originally posted by Steve-the-Duck
      not the least of which was a tendency to spontaneously catch fire.
      Not dissimilar to a ASW Sea King then!!
        • 15692
        Nice improvements to the exhausts.
        • JayCee
          • Aug 2019
          • 1132
          #34
          Hi Richard. No, I came out on one of the last aircraft. Nearly got arrested at UK Customs. They didn't like the fact I was still armed. Seems it was frowned on in the UK.
          John.
          • rtfoe
            • 9084
            #35
            Thank you Jim.
            John.
            John, same reception if you enter my country armed. :smiling2:
            Ceheers,
            wabble
              • 18266
              I do enjoy seeing these older kits being brought up to standard. Nice one Richard.
              • rtfoe
                • 9084
                #37
                Thanks Ian, it's quite fun if reference is available. Because its so small I get away by just eyeballing the detail and measurements. Anyway after that ridiculous jungle diorama I needed some scratch relief. :smiling2:
                Wabble
                • scottie3158
                  • 14201
                  • Holbeach
                  #38
                  Wabble,
                  This is what the fun part is for me, taking an older less detailed kit and giving that tweak to make it better.
                    • 18903
                    Scratch relief and tweaks they call it…..and they are two of the best around in my opinion…….
                    • rtfoe
                      • 9084
                      #40
                      Wabble,
                      Right on Scottie. :thumb2:
                      Touche Tim. :thumb2:
                      Wabble
                      • rtfoe
                        • 9084
                        #41
                        Hi,
                        Today I finished the scribing and sanding down of the rivets, not all the way so there is some trace of it left.
                        The bottom fuselage half was scribed later and I had glued the window on so it needed a masking before sanding.
                        I have to make a decision to really make this a much later version which calls for an enlarged chin and extended engine cowling bases with side mesh or just leave it. I intend to add the side pylons with yellow storage(fuel?)tanks so not sure if this was only on the later version. Anybody have a clue?
                        Wabble
                          • 15692
                          All very neat Richard. What do you use to scribe against? I have used that Dymo embossing tape but wondered what you use to get such neat results.
                          • rtfoe
                            • 9084
                            #43
                            Thanks Jim, I use a draftsman aluminium template as a guide for my scribing tool. I basically work on fuselage halves to get a good lying surface and tape the template at both ends before scribing firstly very lightly and then with deeper strokes after there is a groove deep enough that I can just scribe without the template.
                            I added a tube that doubles up as an air scoop and outlet to prevent an empty hole that reveals the inside of the fuselage.
                            Wabble
                            • Airborne01
                              • Mar 2021
                              • 3968
                              • Steve
                              • Essex
                              #44
                              I will follow if I may. I remember these flying out of RAF Khormaksar (Aden) when I was there in the '60s. Weird, ugly beasts.
                              John.
                              Me too!
                              • rtfoe
                                • 9084
                                #45
                                Hi Guys, todays progress are the following...
                                The exhaust tubes and backing with each marked A to D.
                                Then I over zealously did the cockpit seats without referencing and found after checking that they were rather rudimentary and simple without a head rest. I'm keeping mine on as it looks a little more sofisticated and wasn't going for 100% accuracy.
ID:	1206343...just look at the gaps I will have to fill...
                                Then I made the canvas seat for the crew chief which is basically blutac'd in place for easy painting later.
                                That's all for now and I haven't even started on the external detailing apart from the scribing. Hope you guys like what you see.
                                Wabble
