Oh dear it's a 1/72 Bristol Beveldere
Thanks Scottie.
Thank you too Jim.
Thanks Ian, just using the old grey matter and taking my time to ponder about what to do and come up with a few directions.
Sprayed the items and let them dry, highlighting the rudimentary engine bay turbines so that its seen through the mesh.
I found that Mr Color 312 for the Israeli KfirC is a match for RAF interior green and will be using that from now on.
WabbleComment
Lazy day today and very little done. Basically worked on the rear wing or tail fin whatever its called. I've used the vertical fins and cut them appropriately to fit as the slanted extention. But to do that I had to broaden the tail stabilisers as per reference by adding plastic strip to the edge and filling with putty.
With the left over putty I scratched the fairings to the absorber struts on the front undercarriage.
I used paper thin plastic sheet cut into long rectangles, folded it round the absorbers, inserted putty in between and squished the end edges together. The two part putty acted as an adhesive. Whatever came out from the sides will be sanded flat. Will be doing the same for the rear strut as well.
WabbleComment
[ATTACH=CONFIG]n1207476[/ATTACH]
[ATTACH=CONFIG]n1207477[/ATTACH]
Wabble
Never say that in ear shot of the head gardener, she will find you a job in amongst some plants .
Wobble .Comment
Thanks Jim, it took me a while to figure how best to do the fairings.
WabbleComment
Hi, slightly more productive this time. I've got the stabilisers and undercarriage done. Also added little vents or scoops too.
British designs can either look ugly or futuristic like the tail here.
Drilled out some detail on the fairings and scribing a panel line later.
These are the scoops with ends drilled...funny that they face the opposite way.
Undercarriage fitted...did both simultaneously to get it balanced. Next are close ups...
Not shown are the turbines set at angles towards the prop shafts. I doubt it will be seen through the mesh but did it just in case.
What I have left to do now is the cockpit interior, canopy slide door, cargo slide door, tidying up the air scoops, adding the dingy racks and antennas.
WabbleComment
