Rick’s 1/48 Airfix Sea King HAS5
  • rickoshea52
    • Dec 2011
    • 4076
    • Rick
    I’ll be starting this tonight, in the boring grey scheme. Although the red & grey is quite eye catching I’d prefer a Gannet based cab when decals can be located.
    A quick look in the (jam packed) box has got my tail wagging. Moulded in the new harder plastic the detail is superb. It’s clear there is a HAR3/3A & HC4 coming in future releases.
    Chocks away!
  • Waspie
    • Mar 2023
    • 3488
    • Doug
    • Fraggle Rock
    This is high on my wish list. Like you Rick, I'd prefer to have it in the Gannet SAR colours. Although I spent 8 years on 819 from Mk2's to 5's and 6's. So a dark sea grey would be ok with me too.
    Looks a very good kit, right down to the sonar/radar suite in the rear business end.
    If your going to blog this un I'll grab a front seat please.
    • rickoshea52
      • Dec 2011
      • 4076
      • Rick
      My preference would be for a HAR3 of D flight 202 sqn. A Gannet cab is on the list because they were our sister SAR flight in Scotland, I like the Saltire emblem on the nose too.
      • Waspie
        • Mar 2023
        • 3488
        • Doug
        • Fraggle Rock
        Myself and a Lt/Cdr set up the SAR flight back in 89 from 2 of 819's pingers. (The squadron was already doing SAR duties but at 90 minutes notice so we usually picked up the long range stuff where time wasn't so much a priority). Then in 89 we were told to move to 15 minutes notice, the same as you RAF guys at Leuchars and Lossie).
        We had to have 2 x Mk 6's which annoyed the squadron as we a mix of Mk 5&6's. (819 only had 6 cabs!) Initially we had standard Mk 6's in the standard dark sea grey livery. I left in 90 and shortly after that they changed to the Grey/red livery with the Saltire added to differentiate from 771 SAR cabs at Culdrose. In the end the role of the SAR moved from 819 to 771NAS. All be it 771 is based at Culdrose in Cornwall the aircraft were permanently detached to Gannet at Prestwick airport.
        • Andy T
          • Apr 2021
          • 3239
          Sorry to go off topic but with all this SAR talk I often wonder if you guys ever ran into my little brother, MACR Rich Taylor?
          He tells me little about his career in the RAF but I know he was based mostly at Valley. However he did the rounds as many seem to do, was a SAR instructor for a bit, and was crewed with a rather well known pilot at one time.
          It seems like it would be a rather tight community where you would each know, or know of each other, but I could be completely wrong :smiling5:
          • Waspie
            • Mar 2023
            • 3488
            • Doug
            • Fraggle Rock
            Rick may be the best guy for this Andy. RN and RAF crews rarely met up, even on a job your just a face inside a helmet.
              • 18266
              Well come on Rick, what's in the box!?
              • langy71
                • 1948
                • Chris
                • Nottingham
                It's exactly the same in the Army as well.. I've lost count of the amount of times somebody asked me ''did you know my uncle,cousin,dad...etc....his name is bob, and they called him nobby ?...etc''
                • Waspie
                  • Mar 2023
                  • 3488
                  • Doug
                  • Fraggle Rock
                  Rick, if you need any pics of the inside of a Mk 5, (Don't know which one you're building). I have a couple of pics which shows the avionic set up. The inside of the back of a Mk2 and Mk 5 are virtually the same. It's the Mk 6 where major changes were made to the avionics.
                  I also notice that Airfix are showing the SU, (Submersible Unit or dunking sonar) as having a pale yellow top. (Vanes). This is not the case. It is more a buff colour, again, I have a couple of images if needed.
                  Doug
                  • rickoshea52
                    • Dec 2011
                    • 4076
                    • Rick
                    Doug
                    Send them over Doug. I was going to ask you for your input along the way.
                    Thanks.
                    • rickoshea52
                      • Dec 2011
                      • 4076
                      • Rick
                      It depends when he was in. I was at Lossiemouth from oct 2002 to august 2005. Although the aircrew may have rotated through squadrons and flights or course and FI deployments the ground crew rarely did in my experience. Rich Taylor is a common name and it doesn’t ring any bells.
                      • rickoshea52
                        • Dec 2011
                        • 4076
                        • Rick
                        Sprue shots etc.
                        I’m building version B; medium sea grey over camouflage grey.
ID:	1207859Click image for larger version
ID:	1207860Click image for larger version
ID:	1207861Click image for larger version
ID:	1207862Click image for larger version
ID:	1207863Click image for larger version
ID:	1207864Click image for larger version
ID:	1207865Click image for larger version
ID:	1207866Click image for larger version
ID:	1207867Click image for larger version
ID:	1207869Click image for larger version
ID:	1207870Click image for larger version
ID:	1207872Click image for larger version
                        • rickoshea52
                          • Dec 2011
                          • 4076
                          • Rick
                          And why am I convinced there will be a HAR3/3A & HC4? The HAR3/3A is the RAF yellow variant.
                          There are domed observation windows, two pressure refuel points - one below and one aft of the cargo door. The refuel point aft of the door is suitable for both marks. A blanking plate is provided for the point not being used.
                          See below.
                          There is a troop step and IR jammers for an HC4 (and possibly an AEW/ASaCS).
ID:	1207875Click image for larger version
                          For an HC4 additional sprues for the fixed sponsons will be required. I counted 21 troop seats in this boxing - how many troop seats in a HAS5 v HC4?
                          Three lenses for the pilots and observers controllable spot lamps are on the clear sprue.
                          An early or later HAR3 with the metal blades, FOD deflector and Deccan blister is possible.
ID:	1207878Click image for larger version
                          Composite blades, an EAPS/SNIPS intake filter and MSS/FLIR turret for later HAR3’s are on the sprues.
                          I have noticed that the wheels do not have weight on wheels tyre sag.
                          • rickoshea52
                            • Dec 2011
                            • 4076
                            • Rick
                            And my progress so far.
                            The IP and console are super detailed and include the tail wheel lock and parking brake handles.
                            The broom cupboard aft of the cockpit is also detailed including the relief (pee) tube.
                            I haven’t glued the seats onto the deck yet, I’m using the locating holes as a jig while the seat brace cures to ensure they align correctly.
ID:	1207881Click image for larger version
ID:	1207882Click image for larger version
ID:	1207883Click image for larger version
                            • rickoshea52
                              • Dec 2011
                              • 4076
                              • Rick
                              As well as the line, he wore green/navy blue/blue a lot.
