As I continue to add the glazing and smaller parts to this I picked up on something unique to scheme B in this kit. The rescue winch is not fitted on this version which means the holes in the fuselage for the winch frame needs to be filled.
It’s no big deal but the instructions aren’t clear about it. Because the winch is not fitted the hydraulic and electrical connections will need to be replicated. I did this on a 1/72 HC4 I built last year.
Another detail Airfix have almost missed is the crewman’s grab rail above the main door. I say almost because it’s included in the kit, just not referenced in the instructions.
Masking for the clear parts is complete(ish). The main canopy needs a green tint on the two upper quarters. To do this I masked the inside of the glazing that needs to remain transparent and sprayed Tamiya clear green. This may take a couple of coats until the correct opacity is achieved so I have left two small areas on the outside of the green windows unmasked. When I am happy these areas will be filled in with tape then they can be fitted to the model.
Wipers and screen wash nozzles are unmasked.
