Rick’s 1/48 Airfix Sea King HAS5
Just finished: Airfix 1/48 Stuka & Airfix 1/72 Sea King HC4. -
Been following watching from the cheap seats.
A great build so far with lots to look at.Comment
I’ve now dropped enough hints to SWMBO, No’s 1 & 2 sons. So if it isn’t under the tree at Chrimbo, some people ain’t going to be having stuffing with their turkey!!!!Comment
Just finished: Airfix 1/48 Stuka & Airfix 1/72 Sea King HC4.Comment
I have a mystery to figure out, what is this round fitting under the lower personnel door? I don’t recall seeing this on the HAR3’s I worked on and all references I can find suggest it was plated over on later marks of Sea King.
Not a big deal but there is no reference in the instructions and I’ll be posing the door open so it will be hidden.
As you can see, the glazing is attached and the closed option for the forward door is being used as a mask.
[ATTACH=CONFIG]n1210169[/ATTACH]Comment
No. The earth point is a brass stud and wing nut in the hull if I recall correctly. My thoughts are it is a vent for the avionics equipment compartment under the cockpit or a blow off relief valve for fuel over fill. It seems only applicable to early Sea Kings.
I’ve looked at HAR3’s, HC4’s and Mk43’s which all have a blanking plate riveted over this area.On the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
I looked at my pics of RN Sea Kings and it appears some do and some don’t as you say. The avionics theory would be my guess!!!
Tbh, I’ve never heard of a blow off on the fuel system. We used pressure refuelling as you probably know and sensors in the tanks automatically shut off when the tanks are full.Comment
Tbh, I’ve never heard of a blow off on the fuel system. We used pressure refuelling as you probably know and sensors in the tanks automatically shut off when the tanks are full.On the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
This is just superb, brilliant modelling and reference material, can i ask a newbie question, what is the 'bean tin' and how did it contribute to the crash of the 819 helicopterComment
