Airbrush... You need to strip it down to the bones. Leave it in a pot of IPA overnight and then go for a full clean. What has happened is that when cleaning the airbrush the varnish has thinned and not all been washed away. The air still coming out of the brush even though you have not pressed the trigger is the valve sticking. I have this still on a couple of mine and normally if it happens I just flick the trigger to the up position. With the valves I have cleaned them, replaced the rubber ring/seal, left them to dry for days before assembly and still it happens - I now let it dry for a couple of days in the airing cupboard, then dust it with a bit of talcom powder which helps most of the time.
Also check the needle because when you assemble and there is still a bit of moisture left, the needle develops a ring around where it joins the tunnel, again mine is left out untill I am ready to spray, but don't do what I have done on a couple of occasions, started spraying and wondering why all the paint is going over my hand and not on the model - and that is a clean up job.
