Doug's 1/48 Airfix Sea King
    You‘re doing very well, especially in finding ways to repurpose bits from entirely different types of kit
    • JayCee
      • Aug 2019
      • 1132
      #77
      Most excellent scratchy work, Doug. Spares from old kits do come in handy. :thumb2: :smiling3:.
      John.
      • Waspie
        • Mar 2023
        • 3488
        • Doug
        • Fraggle Rock
        #78
        Originally posted by Jakko
        John.
        You‘re doing very well, especially in finding ways to repurpose bits from entirely different types of kit :smiling3:
        As I'm finding chaps.
        • Andy the Sheep
          • Apr 2019
          • 1864
          • Andrea
          • North Eastern Italy
          #79
          A maybe silly question: isn't the P tube a tad high?
          Considering its name, shape and position, I came to the conclusion its function is to ease the crew bladders, heavily challenged by the vibrations and cold during long flights.
          If I'm right, then or the users had to bend their head and raise on their feet to reach it or the tube is not fixed but detachable to be bent to the needed height...
          If I'm wrong and the P tube has a different use, then this is a first class silly question :smiling6:
          • rickoshea52
            • Dec 2011
            • 4076
            • Rick
            #80
            The relief tube is retained by a clip on the side of the broom cupboard door. Undo oneself, undo the tube, relieve oneself and get back to flying.
            Edit: deleted incorrect statement.
            • Waspie
              • Mar 2023
              • 3488
              • Doug
              • Fraggle Rock
              #81
              Cheers Rick!! I’ll have a look!!! I wonder how I missed that! More surgery when I find it. Still, a good exercise!! (And another lesson learned - check and double check)
              • rickoshea52
                • Dec 2011
                • 4076
                • Rick
                #82
                Actually Doug, I wrote that comment then double checked and found I was thinking of the 1/72 kit. I didn’t delete that draft statement so when I replied to Andy it was still there. I’ve edited it now.
                • Allen Dewire
                  • 4741
                  • Allen
                  • Bamberg
                  #83
                  I had to re-read this thread a few times and YUP!!!....Doug is doing some fantastic scratchy and for the first time too!!! Wonderful work Sir and knowing very little about whoop whoops, I can only say, you are doing an excellent job on it!!! Most of all, you're having fun too...
                  I'm in on this and please keep it coming!!!...
                  Allen
                  PS, don't forget to clip the tube back up when you're done Buddy..................
                  • Waspie
                    • Mar 2023
                    • 3488
                    • Doug
                    • Fraggle Rock
                    #84
                    Problem is!!! I have found the part!! F49!! Trouble now, well not really trouble, I now cannot find any reference to F49 in the destructions. Not even an image!!
                    Too late now anyway, it’s fitted!!
                    The scratchery was a good way to practice. Going to re- scratch a sonar foot brake using my newly acquired plastic sheet!!
                    Onwards and upwards!!
                    • Waspie
                      • Mar 2023
                      • 3488
                      • Doug
                      • Fraggle Rock
                      #85
                      Hi Andrea, as Rick said, the 'P'tube is the correct height and help in place by an open ended clip. The length gave the user a wee bit of flexibility to move around a little. After struggling with your doings on your immersion suit you needed the extra length!!! It was the responsibility of the user to clean the thing after use. (Needless to say - it wasn't used too often).
                      On certain flights and depending on the passengers, we used to tell the pax it was the emergency comms device to talk to the pilots. Like the voice pipes of older ships. Amazing how many people fell for it!
                      • Waspie
                        • Mar 2023
                        • 3488
                        • Doug
                        • Fraggle Rock
                        #86
                        A very quick update.
                        Spent much time searching the instructions for a part that is on the sprue but no mention on the plans. Note to Mr Airfix - Buck up!!!
                        Did some painting, the Ron way. Better results today. Happy, I now have painted passenger seats and the internal cabin and cabin floors have been hairy brush painted. Still to humid, (and cold), for the AB.
                        However, the bit I am really chuffed about is the transducer. (The dangly bit that goes in the water). Attached the Eduard PE transducer face. Which in the real world is 4 strips of 13 small transducers, which sends out enough power to boil water when transmitting! (For those without 'O' Level sums, that 52 individual transducers.) Hopefully the PE version is better than the decal Airfix supply!!
                        Pic - Transducer.
                        And now one in focus!!!!
                        • Andy the Sheep
                          • Apr 2019
                          • 1864
                          • Andrea
                          #87
                          Thank you, Doug and Rick. I saw a P tube on a C130; I didn't examined it from close distance (guess why! ) but it looked as if it was fixed, that's why I had that doubt. :thumb2:
                          :tears-of-joy: I never trusted air crews when talking about weird on board objects... I have always known they have a peculiar sense of humor and sometimes with a vengeance if the passenger deserved it!
                          • Waspie
                            • Mar 2023
                            • 3488
                            • Doug
                            • Fraggle Rock
                            #88
                            Very sensible!!
                            On board, embarked with the Wasp, I was always using my Blue Peter skills to produce dummy weapon systems. (Just for our Soviet friends).
                            I was also known to manufacture a huge key which fixed into the on board flare receptacle. Pilot used to slowly start a very slow descent. I would then ask the passenger(s) in the back to wind the key to put some more tension in the elastic band that powered the engine. If they didn't wind the key the pilot would start a quicker descent. It was amazing seeing them wind it up before the aircraft went into a full Auto-rotation!!!
                            I also developed, (and sold the plans on board), a hand held bazooka made from baked bean tins and fired soft projectiles. Sadly, the skipper banned it after getting clocked with a sock wrapped in black masking tape!!! Was fun while it lasted!!!
                            • Andy the Sheep
                              • Apr 2019
                              • 1864
                              • Andrea
                              #89
                              Very sensible!!
                              I guess there's a thick dossier at GRU HQs in Moscow with your name on its cover, Doug!
                              • Waspie
                                • Mar 2023
                                • 3488
                                • Doug
                                • Fraggle Rock
                                #90
                                I offset that by wearing a Soviet fur lined hat sporting the Hammer and Sickle!!! The captain used to tell inspection staff I was getting inside the old Soviet mind!!! It did keep your head warm too!!!
                                I used to take enough pics of them being the ships int photographer!!!!
