Doug's Westland Wasp by LF, the build!
I have spent the weekend and a portion of today attempting to assemble the flotation gear!! Every combination of fitting has been tried and still the flotation cans don't sit right - I surrender!!!
[ATTACH=CONFIG]n1230033[/ATTACH]
The white flag is now flying over the bench! I give up!!
Wasn't going to let a piece of plastic get to me but this kit has. From start to ¾ built it has made me want to take up knitting. It now resides in its box stored for whenever I acquire the skill set or 'want' to see this kit completed.
If I don't walk away from this I can see it putting me off what I have until recently - enjoyed. So in the interest of sanity - the end to the Westland Wasp by LF.
For those who have this in their stash. Don't let my experience put you off. You are probably a lot more skilled than I and won't find it half so troublesome as I have. This is only my 5th kit since taking up the hobby so not too disheartened!!!!
Lets hope HobbyBoss kits are less bother?Comment
Just downloaded and looked at the instructions....
You may have tried this but here goes...
Cement part 44 to 43 and let dry enough that you can move it and make adjustment if required. Then cement part 43 to the frame 41 and set aside to dry.
Then fit part 42 and allow to dry and finally add part 45.
I know it is ok to sit on the sidelines and give advice.Comment
Oh, any advice is always welcomed, sidelines or otherwise.Comment
After a session on the Helix, I opened the box with the Wasp in it and cast my eye over it again.
Identified the parts for the flotation equipment and tried - I reiterate - TRIED to dry fit the struts and flotation cans. No way would they go together as they should. I even had a go at swapping the left and right flotation clams over and still no luck.
I have had an idea but it will mean buying some round plastic rods and making some bespoke struts to ensure it all sits correctly.
I'll have to try and remember to measure them tomorrow, (diameter), then order some plastic.
I still think this Wasp is 100% worst kit I have encountered to date. Not giving up though!!!!!!
Worst case scenario. I'll buy an air rifle and use it as target practice!!!!!!Comment
If you only need small diameter rods and not to long bits, could you not stretch some sprue to size and cut that up? Just a thought.Comment
OK, quick update. I have just ordered some 0.5mm plastic rod to enable me to complete the Wasp. The problem has been the kit supplied parts are either wrong in dimensions or I have somehow cut them wrong! (Which I don’t believe I have). So to rectify it I will cut each strut separately which will allow the flotation clams to sit correctly.
Ian M I did try stretching some sprue. All failures, too thin, too fragile just plain messy. (And as SWMBO pointed out - “look at all the chemicals near that candle”.)
So! When I am able to return to the bench/garage I will be in a position to finally complete that stage. All that will be remaining then is fit the missile booms and scratch two wind deflectors for the front doors!!!👍 2😂 1Comment
Step forward today. Well virtually!!
SWMBO gave imperial permission for me to work indoors, (only as far as the kitchen), to work on the Wasp. (Can't touch the Helix as that requires spraying and her asthma won't run to lungfuls of spray!!! (Wuss).
So with some luck I will be able to get stuck into the flotation equipment with the acquired plastic rod. (Soon!) Watch this space!!😀 3👍 2Comment
