Have to admit, that option never crossed my mind. Purely because the length? Height? of the sight is about 6mm maybe 7mm. Also, the cut would have had to have been slightly diagonal making it that bit more difficult as get the angle wrong and it most definitely would have looked wrong, externally and internally!!
Thanks Tim. I thought when I drilled the 3mm hole that would be it but when I offered the sight to the hole - nah!! It no fit, so I went another ½ mm and nope, the 4mm was just right. I didn't think my pin vice was going to accept the 4mm drill bit but it was fine. Didn't fancy using the Dremel even at its slowest speed for fear of melting the plastic!!
