Rick’s 1/72 Airfix Chinook HC1 - Bravo November - a dream sheet build
Posts
  • A_J_Rimmer
    • May 2024
    • 801
    • Arnold
    • North Wales
    #31
    Originally posted by Waspie
    Missing the pedals out seems a big omission from Airfix. Grand job in rectifying their error.
    Seems to be par for the course for most Helo kits.
    Superb detailing work on that interior!
    Arnold Judas Rimmer BSc SSc
    ''Happiness is a Triple Fried Egg Sandwich with Chilli Sauce and Chutney''
    • rickoshea52
      • Dec 2011
      • 4076
      • Rick
      #32
      Fuselage and interior all joined up. The transmission tunnel panels hide the join but before that some holes need to be drilled using the jig provided. It’s easy to use with idiot proof locating lugs to aid positioning. The lugs also aid with fitting the tunnel covers.
ID:	1228542Click image for larger version
ID:	1228543Click image for larger version
ID:	1228544Click image for larger version
ID:	1228545Click image for larger version
ID:	1228546Click image for larger version
      • rickoshea52
        • Dec 2011
        • 4076
        • Rick
        #33
        Thanks for all the positive comments and likes etc. so far. Happy to know this build is attracting some interest.
          I like that they provide a jig to drill holes — though I do kind of wonder why they didn’t just mould indentations in the underside. Regardless, more manufacturers could take a cue from this example and provide jigs for tasks like this, or for bending photoetched parts into precise shapes.
          • A_J_Rimmer
            • May 2024
            • 801
            • Arnold
            • North Wales
            #35
            Very much so - it's such an iconic aircraft and it's great to see a decent kit and build of it. You're interior detailing was a great addition.
            I love that jig idea - it'd be great to see some more of this kind of thing. Airfix gets a lot of stick from some circles, but I do thin they're genuinely trying to up their game.
            • rickoshea52
              • Dec 2011
              • 4076
              • Rick
              #36
              Another omission from the kit are the two strakes along the lower rear fuselage. How these were missed is a mystery but to be fair to Airfix, the Revell Chinook kit also misses them.
              So out with the plastic strip, scalpel and ruler. Using reference photos as a guide the strakes run from the middle of a panel under the bubble window to the rear landing gear bay and along the fuselage side to underside panel. I measure this to me 37mm long. Plastruct 0.5x1.0mm strip was cut to length with the ends trimmed with an angle.
              Glued on with thin cement using a steel rule to ensure straightness and the correct flare outwards this was a simple detail addition.
ID:	1228786Click image for larger version
ID:	1228787Click image for larger version
              • Andy T
                • Apr 2021
                • 3239
                #37
                Loving the extra work you're putting into this.
                The jigs are a great idea, my Airfix Gannet had something similar
                • A_J_Rimmer
                  • May 2024
                  • 801
                  • Arnold
                  • North Wales
                  #38
                  Interesting that that was missed, A great bit of correction work though.
                  • rickoshea52
                    • Dec 2011
                    • 4076
                    • Rick
                    #39
                    Now with paint. The grey/green is on, in this photo there is some masking tape applied where a touch up is required. Next step is to mask a wavy line for the black underside.
                    • HAWKERHUNTER
                      • Feb 2012
                      • 1666
                      • Steve
                      • Halifax, West Yorks.
                      #40
                      Coming on nicely Rick and a very detailed and informative build thread. Classic helicopter.
                      • Mark1
                        • Apr 2021
                        • 4156
                        #41
                        Looking good with some colour on :thumb2:
                        • flyjoe180
                          • Jan 2012
                          • 12488
                          • Joe
                          • Earth
                          #42
                          Enjoying catching up on your Chinook Rick
                          • rickoshea52
                            • Dec 2011
                            • 4076
                            • Rick
                            #43
                            Back to the bench after holiday and business travel and I’ve applied the black underside and rotors with Tamiya XF-69 NATO black. The rotors got a slapdash application of XF-1 flat black for a bit of a weather beaten effect.
                            The first coat of varnish applied (Mig paint is soooo fragile). A second will go on before decals go on.
ID:	1230572Click image for larger version
                            • rickoshea52
                              • Dec 2011
                              • 4076
                              • Rick
                              #44
                              Deathship decals applied.
                              All the aircraft serials, roundels and sqn decals done. Al of the RH side stencils and most of the walkways are applied. Only the LH side, engine and blade decals to do. I hope to have this done for the IPMS Stoke show next weekend.
                              A point to note: the fin flashes need to be applied before the VOR-D aerials as I discovered too late.
ID:	1230886Click image for larger version
ID:	1230887Click image for larger version
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #45
                                VERY nice build Rick
                                chrisb
