Doug's 1/48 - KA27 Helix by Hobby Boss
Looking good to me. Sure, it’s not exactly the kit part, but bodging something together this way is always better than not having anything at all thereComment
Thanks Jakko and thank you for the kick I needed to give this a go. Another bit of DIY under the belt. Every bit I do means I gain in confidence to do little jobs like this. Also kept SWMBO happy as it saved me spending $24 on as she says, 'a tiny bit of plastic'.Comment
99% of the parts I drop end under the bench and by the wall yesterday was a bad day but at least I got my cardio for the day! lol Also considering a light under the desk!
Great job on scratching the part that went AWAL.Comment
Thank you for the scratchery comment, appreciated Ian.
Never had to work in such small scale. The purchase of magnifying glasses a few months back is paying off now!!Comment
Posting while I have the chance, I spotted SWMBO making a start on a new list this morning!!!!
I managed to complete the lower rotor head, AND, without loosing a single piece. Only one ping out of the tweezers and that was recovered in seconds. (a tiny control arm).
The finished article, both upper and lower heads.
Pic 1
The two heads are not physically connected just yet as I am not sure how the shaft, (a metal hexagonal rod), interacts with the two separate heads!!
One thing I found handy, something most of that have built choppers have pondered over and designed our own solutions. Blade droop. The dipping of the rotor blade from root to blade tip.
Well, Mr Hobby Boss has thought of that. Have a look at the image and see how they have attached the blades to the sprue. Damn clever!!
Pic 2
Now if they have induced a twist in the blade as well, I WILL be impressed!!
That's all folks.
C&C's always welcomed.
DougComment
Superb bit of scratch-building on that replacement part Doug and great progress thus far. I've always had a soft-spot for Kamovs so it's great seeing one built.Arnold Judas Rimmer BSc SSc
''Happiness is a Triple Fried Egg Sandwich with Chilli Sauce and Chutney''Comment
Anyway, blade droop is easy: just hold the blade tight the blade between thumb and forefinger of both hands, pressed against each other, and bend the blade slightly. Repeat every centimetre to centimetre and a half over about two-thirds of the blade length (from the hub outward) and it will look pretty convincing.Comment
But what if I want to build the model in flight?!
I learned the thumb forefinger technique on here after a couple of my test theories failed!!Comment
Only a wee bit of progress today. (SWIMBO's list came into effect!).
Dry fitted the rotor heads to the assembly that would be the gearbox. A metal hex drive shaft connect the two heads to the fuselage.
Pic 1.
Then I started on the tail external sections. In this case the stabilisers, only managed to get one side completed.
I do like this kit - everything fits together so well. Learning from previous builds that dry fitting is key. However, this doesn't really need it.
Pic 2
Once I have all the sub assemblies put together I will start on the painting.
Oh, I did manage to mask off the main cockpit windows. No pics!!
That's all folks, for today!
DougComment
