[ATTACH]46502.vB[/ATTACH]Update on this one - got sidetracked on a few other projects since this last post including taking in another Heli (A Classic 1980's machine too) I will be posting more on here shortly
As you can see since my last pic - that sheet of liteply has been transformed into individual components, all cut & rounded out by hand. Papered both sides (seals & strengthens the wood) finally coated with cellulose dope - 2 coats each side and sanded after each coat to give a perfect finish ready for painting. Paint is aircraft interior grey on the final assembled modules...pics to follow
Final test fitting and trimming of all those parts above has been done and the fuselage checked out with a spare set of mechanics to check mounting positions etc. Final step is to check and repair any remaining blemishes on the shell and then I can commence the spray job. I have all the markings and logos all prepared on the computer. When the paint job is done they will go on.
In the meantime I have acquired another 3 Helicopters, a Thunder Tiger Raptor 30 V2, An original rare 1980's Heim Lockheed 286 and a Graupner Heim Ecureuil AS-355
Ps...the machine in the background of the pic is a 1990 MFA Sport 500 under restoration and conversion to a collective pitch head and full MD 500E Fuselage.
Latest news on this one is that it is now Flybarless, I haven't bought one of the new fancy heads for this but have actually used original Kalt parts and modified the head. This has left a very tidy setup with only 2 linkages from the swash scissor mechanism to the rotor head, exactly as on the real 222 - it works perfectly and looks very scale indeed
After cutting out a lot of those wooden parts in the original pic, most of them were not needed so were left out in the fuselage build. I did make up one or two new bits purely for strengthening the fuselage. I remade all the tail parts (not shown in the pics) and adopted a different mounting method for the stabiliser bars with the side fins on. The plans suggested drilling through the tail boom and fitting these with specially bent rods - far too fiddly as I have found out on one of my other heli's that has this same system. I have gone for a more direct mounting of these parts which is a lot easier and as it happens, it is exactly as per the full size 222.
As for the rotorhead I mentioned - a couple of pics for you.
First is the head with the flybar pivot tower still attached - the black tape on the shaft marks the cutting line. 2nd pic is with the pivot tower removed and cutting tidied up - leaving a very scale like flybarless head. This now only requires 2 linkages to make it work compared to 7 on the original flybar head
