AB-47 Esercito Italiano
    Thank you mates.
    Slowly moving on now. Working to complete the tail with the oil tank, stabilizers, some pipes, battery and tail end and rotor. It will take few more days to complete this part.
    I've sprayed some Gunze gloss on stabilizers and got a non smooth surface, transparent was thinned 50/50 with IPA. I will spray another layer today, suggestions?
    Thank you for following.
    Francesco
    • eddiesolo
      • Jul 2013
      • 11193
      #32
      That is looking the business now Francesco, superb build. Really like this mate.
      Si
        Originally posted by \
        That is looking the business now Francesco, superb build. Really like this mate.Si
        Thanks Si
        Almost done with the engine ... Now the hard part will be to push it into the frame
        [ATTACH]74313.IPB[/ATTACH]
        [ATTACH]74314.IPB[/ATTACH]
        [ATTACH]74315.IPB[/ATTACH]
        [ATTACH]74316.IPB[/ATTACH]
        Francesco
          one wrongly applied decal and one destroyed ...
          Tempted to throw it away now
            Here it goes
            [ATTACH]74375.IPB[/ATTACH]
            [ATTACH]74376.IPB[/ATTACH]
            All together
            [ATTACH]74377.IPB[/ATTACH]
            Francesco
              • 22788
              #36
              Just caught up on this Francesco great work and with all the trails and tribulations makes it an even better build
              • flyjoe180
                • Jan 2012
                • 12463
                • Joe
                • Earth
                #37
                Looking very nice now Farncesco, good job on the engine installation and all that tubing
                  Thank you mates.
                  Yesterday I completed the tail, added guide wire to the rotor, mounted the avionics module. Today I assembled and painted fuel tanks and the top castle, fixed and painted the cabin side damaged to remove the decal.
                  I'm still trying to remove without damage the decal on the tail, but I'm not positive. It's taking a bath since more than one hour and it doesn't move yet. I will leave it overnight and see tomorrow morning.
                  Still have to complete support for the tanks and the torque tube, then all the pieces should be there for the final assembly. I'm starting to see the light.
                  Francesco
                  • yak face
                    • Jun 2009
                    • 13870
                    • Tony
                    #39
                    Cant wait to see it Francesco , cheers tony
                    • flyjoe180
                      • Jan 2012
                      • 12463
                      • Joe
                      • Earth
                      #40
                      Looking at the detail you;re putting into this build Francesco, I think I will not be attempting mine for a while yet.
                        Thanks again, adding a pic
                        [ATTACH]74485.IPB[/ATTACH]
                        Francesco
                          Waiting to solve the issue with decals, BTW yesterday I unsuccessfully did the last try to remove them, I recovered this old kit, started more than 20years ago and never finished. After two days of sanding to remove the tons of glue, puttying to cover the grooves and weakly rescribing, yesterday I finally tried to airbrush my first mimetic livery. Colors are the one I had home and the scheme I tried to extract from some pic. What do you think?
                          [ATTACH]74528.IPB[/ATTACH]
                          [ATTACH]74529.IPB[/ATTACH]
                          I'm posting here as this model will never see the light cause I've not found transparents and decals, must have hidden very well to avoid to damage them.
                          Francesco
                          • flyjoe180
                            • Jan 2012
                            • 12463
                            • Joe
                            • Earth
                            #43
                            From what I can see that camo job looks good on the Starfighter Francesco.
                              Thanks Joe, just need to glue the loads now. One day I may try to vacu-form the canopy and complete this.
                              [ATTACH]74641.IPB[/ATTACH]
                              Now back the AB-47.
                              Francesco
                                Errata corrige, now is complete:
                                [ATTACH]74644.IPB[/ATTACH]
                                Francesco
