This is the Eduard 1/72 strip-down Fokker Dr.1, which is (almost) entirely photo-etch. (You can see pics of the kit contents in Gregg's thread.) The build was more straightforward than it might look, though I still found it a challenge, largely due to my own clumsiness; I even managed to knock it flying across the workbench a couple of times when it was close to being finished. There's a full build article in the latest Airfix Model World.
Skeletal Fokker
Tags: None
Thanks Alan. No, it's all photo-etch painted to look like wood (except the prop, which is plastic...)Comment
Originally posted by \This is the Eduard 1/72 strip-down Fokker Dr.1, which is (almost) entirely photo-etch. (You can see pics of the kit contents in Gregg's thread.) The build was more straightforward than it might look, though I still found it a challenge, largely due to my own clumsiness; I even managed to knock it flying across the workbench a couple of times when it was close to being finished. There's a full build article in the latest Airfix Model World.
I bought another I saw cheap, to use as spares for what I know I would break/lose
No way I can do this justice, and after I'd bought the Tamiya photo etch scissors as well !!!!!!!
GreggComment
That is rather amazing. You even made my wife swear (again).
Great job on the wood effect.
Ian MComment
Thanks a lot for your kind comments.
Originally posted by \I'd take my hat off to you Mike,if I wore one.Thats way beyond my skill level.Did you use solder or superglue?.The wood effect on the prop is very impressive.Comment
Very nice indeed Mike.
It looks incredible and then with the Tamiya bottle next to it I realised the scale very dramatic.
Which optician's do you go for wonder specs ?
LaurieComment
Wow! Simply perfect!
The wood effect is great.
I have been 5 minuts looking and observing how you do the wood effect
Will try itComment
